Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get or post comments on designs through python?
1 REPLY 1
alexXMC9K
304 Views, 1 Reply
As per above; Is there currently any way to pick up a new comment on an active design as an event i.e. get a copy of the message as text etc ? Failing that, is it possible to post a comment on an active model through python?
We self host Rocketchat for team messaging and I would like to have fusion send an update to the relevant channel
( i.e. any models in x directory post to x channel ). I can post from a fusion script via RocketChat's rest api and it works fine (screenshot illustrates what i'm after ) But I don't know how to actually access the comments.
The only other thing i can think to do is to make my own comments box using a panel and replace the inbuilt comments but this feels a bit messy and probably not worth the effort
Alex
1 REPLY 1
goyals
in reply to: alexXMC9K
I do not think it is possible to do that through Fusion API at present.
Shyam Goyal
Sr. Software Dev. Manager
