Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Get geometry (loop) from specific face
1 REPLY 1
xenia.pie
193 Views, 1 Reply
Hi all,
I'm trying to get the geometry of a face for generating up and down faces and be able to generate an SVG of those.
I get to see the geometry of both faces, but for some models the geometry is a bit wrong.
Context:
I loop first through the loops of the face and check count of edges, if edges.count ==1 then is a circle or ellipse and I get the geometry generating the svg path for each specify type. (this is working fine)
But if the edges.count > 1 then I loop through coEdges of the loop to get the curve type and also to identify if the segment is reversed.
            else:
                path = ""
                start = None
                end = None
                c = 0
                for coEdge in loop.coEdges:
                    reversed = False
                    edge = coEdge.edge
                    curve_type = edge.geometry.curveType
                    # determine if edge is reversed
                    isOpposedToEdge = coEdge.isOpposedToEdge
                    isParamReversed = coEdge.isParamReversed
                    (returnBool, startPoint, endPoint) = edge.evaluator.getEndPoints()
                    if self.getTwoD(u, v, endPoint) == end or self.getTwoD(u, v, endPoint) == start:
                        reversed = True
                    if self.getTwoD(u, v, startPoint) == start:
                        print('wrong direction')
                    start = self.getTwoD(u, v, startPoint)
                    end = self.getTwoD(u, v, endPoint)
                    if c == 0:
                        if coEdge.isOpposedToEdge and coEdge.isParamReversed:
                            path = f"M {end[0]} {end[1]}  "
                            path += self.getLineArcPath(start, edge, face, reversed, direction, coEdge)
                            start,end = end,start
                        else:
                            path = f'M {start[0]} {start[1]}  '
                            path += self.getLineArcPath(end, edge, face, reversed, direction, coEdge)
                        c += 1
                    else:
                        if coEdge.isOpposedToEdge and coEdge.isParamReversed or reversed:
                            path += self.getLineArcPath(start, edge, face, reversed, direction,coEdge)
                        else:
                            path += self.getLineArcPath(end, edge, face, reversed, direction,coEdge)
                        c += 1
If curve.type is 0 then it's a line segment:
if curve_type == 0:
  path = f"L {end[0]} {end[1]}  "
and if curve.type == 1 it's a curve segment:
elif curve_type == 1:
            face_normal = face.geometry.normal
            arc_normal = edge.geometry.normal
            opp_or_equal = self.check_vectors(face_normal,arc_normal)
            arc = edge.geometry
            rx = str(arc.radius)
            ry = str(arc.radius)
            rotation = "0"
            large_arc_flag = "0"
            sweep_flag = "0"
            angle = abs(arc.endAngle - arc.startAngle)
            if angle >= 3.141592653589793 :
                large_arc_flag = "1"
            if direction == 'up':
                if coEdge.isParamReversed ==  True and coEdge.isOpposedToEdge == True and opp_or_equal == 'opposite':
                    sweep_flag = "1"
                if coEdge.isParamReversed ==  False and coEdge.isOpposedToEdge == False and opp_or_equal == 'equal':
                    sweep_flag = "1"
            if direction == 'down':
                    sweep_flag = "0"
                if coEdge.isParamReversed ==  False and coEdge.isOpposedToEdge == False and opp_or_equal == 'equal' or reversed:
                    sweep_flag = "1"
                if coEdge.isParamReversed ==  True and coEdge.isOpposedToEdge == True and opp_or_equal == 'equal':
                    sweep_flag = "1"
                if coEdge.isParamReversed ==  False and coEdge.isOpposedToEdge == False and opp_or_equal == 'opposite' or reversed:
                    sweep_flag = "1"
            x = str(end[0])
            y = str(end[1])
            path =f"A {rx} {ry} {rotation} {large_arc_flag} {sweep_flag} {x} {y} "
I have separated between up and down faces (direction) since the arc normal and plane/face normal will be different and hence the sweep_flag will change since I'm using the same plane for both.
The question is, how to get the right segment direction and determine large_arc_flag and sweep_flag in order to have the outline of the face properly defined.
This same code works for some models and doesn't for others.. so maybe there's a simpler way of determine the paths?
This model is alright.
Up faces - working fine
down faces - some line are ok, but the arcs are randomly wrong
Any comments will be appreciated.
1 REPLY 1
kandennti
in reply to: xenia.pie
Hi @xenia.pie .
I would like to try it, but I couldn't because the code you provided is partial and you didn't provide any data (f3d) that doesn't work.
Therefore, it is very likely that I do not understand the meaning of your question.
I have created a simple script to check.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Face'
        selFiltter: str = 'Faces'
        sel: adsk.core.Selection = selectEnt(msg, selFiltter)
        if not sel:
            return
        face = sel.entity
        app.log(u'TextCommandWindow.Clear')
        for loop in face.loops:
            app.log(f'** loop start **  isOuter:{loop.isOuter}')
                geoType = coEdge.edge.geometry.objectType.split('::')[-1]
                st, ed =  getPoints(coEdge.geometry)
                msgLst = [
                    f'---',
                    f'edge type:{geoType}',
                    f'isOpposedToEdge:{coEdge.isOpposedToEdge}',
                    f'isParamReversed:{coEdge.isParamReversed}',
                    f' start point: {st.asArray()}',
                    f' end point: {ed.asArray()}',
                app.log('\n'.join(msgLst))
            app.log('** loop end **\n')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getPoints(geo):
    eva: adsk.core.CurveEvaluator2D = geo.evaluator
    _, st, ed = eva.getEndPoints()
    return st, ed
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        app = adsk.core.Application.get()
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
I tried it with the attached f3d file and noticed that the isOpposedToEdge property is different for arcs created with 3D fillets and arcs created with sketches.
