Get Drawing Sheet Size (A1, A2, A3 or A4) using a Fusion 360 Python script
isocam
isocam
Can anybody help?
Is it possible, for testing purposes, to get the drawing sheet size (A1, A2, A3 or A4) using a Fusion 360 Python script and display it in a message box?
Many thanks in advance!
Darren
BrianEkins
The API currently has almost no functionality for drawings.  The first of any drawing capabilities were just added to the API within the last couple of months.  With it, you can access a DrawingDocument and the Drawing product it contains and get access to the ExportManager object to be able to export the drawing as PDF.  That's it.  There's no access to the sheets or anything else that is drawing specific.
Brian Ekins
kandennti
Hi @isocam .
This is a forced method, but I tried it and was able to get the following characters.
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
import adsk.drawing
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        drawDoc = adsk.drawing.DrawingDocument.cast(app.activeDocument)
        if not drawDoc: return
        size = getSheetSize()
        if not size: return
        ui.messageBox(size)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getSheetSize() -> str:
    app.executeTextCommand(u'Commands.Start FusionChangeSheetSizeCommand')
    dlgInfos = app.executeTextCommand(u'Toolkit.cmdDialog').split(',')
    app.executeTextCommand(u'NuCommands.CancelCmd')
    lst = []
    for idx, info in enumerate(dlgInfos):
        if 'Label=' in info:
            lst = dlgInfos[idx+1].splitlines()
    if lst:
        return lst[0]
    else:
        return ''
