Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Generating extrusions - Causes 'Direction Tool Body Creation Failed'
9 REPLIES 9
Message 1 of 10
Six1Seven1
394 Views, 9 Replies
I am trying to create 4 holes via extrude>cut.
User specifies distance apart in both X and Y axis.
I am creating TWO different sketches in the function and 2 extrusions per sketch to create 4 holes total. Any guesses? I know this has been discussed HERE<--- but not much info was given.
Thanks in advance.
Here is the code:
def holePat(hole_dia, hole_spcX, hole_spcY, hole_cb, length_in, width_in, thick_in):
        act = app.activeProduct
        rootComp = act.rootComponent
        ui = app.userInterface
        #total_length = inputs.itemById('length_in').value
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch2 = sketches.add(xyPlane)
        sketch3 = sketches.add(xyPlane)
        spcX_plus_holerad = (hole_spcX + (hole_dia))
        spcY_plus_holerad = (hole_spcY + (hole_dia))
        if hole_cb == True and hole_dia > 0:
            if spcX_plus_holerad >= length_in:
                ui.messageBox('Oops! User Specified Hole Spacing Greater Than or Equal To Part Length')
            else:
                Load_circles = sketch2.sketchCurves.sketchCircles
                circle1 = Load_circles.addByCenterRadius(adsk.core.Point3D.create((hole_spcX/2), 0, (thick_in)), (hole_dia/2))
                circle2 = Load_circles.addByCenterRadius(adsk.core.Point3D.create((hole_spcX/-2),0, (thick_in)), (hole_dia/2))
                circle3 = Load_circles.addByCenterRadius(adsk.core.Point3D.create(0, (hole_spcY/2), (thick_in)), (hole_dia/2))
                circle4 = Load_circles.addByCenterRadius(adsk.core.Point3D.create(0,(hole_spcY/-2), (thick_in)), (hole_dia/2))
                cuts = rootComp.features.extrudeFeatures
                extInput1 = cuts.createInput(sketch2.profiles.item(0), adsk.fusion.FeatureOperations.CutFeatureOperation)
                extInput2 = cuts.createInput(sketch2.profiles.item(1), adsk.fusion.FeatureOperations.CutFeatureOperation)
                extent_all_ne = adsk.fusion.ThroughAllExtentDefinition.create()
                extInput1.setOneSideExtent(extent_all_ne, adsk.fusion.ExtentDirections.NegativeExtentDirection)
                extInput2.setOneSideExtent(extent_all_ne, adsk.fusion.ExtentDirections.NegativeExtentDirection)
                ext1 = cuts.add(extInput1)
                ext2 = cuts.add(extInput2)
            if spcY_plus_holerad >= width_in and hole_dia > 0:
                ui.messageBox('Oops! User Specified Hole Spacing Outside Part Extents')
            else:
                Load_circles = sketch3.sketchCurves.sketchCircles
                extInput3 = cuts.createInput(sketch2.profiles.item(0), adsk.fusion.FeatureOperations.CutFeatureOperation)
                extInput4 = cuts.createInput(sketch2.profiles.item(1), adsk.fusion.FeatureOperations.CutFeatureOperation)
                extInput3.setOneSideExtent(extent_all_ne, adsk.fusion.ExtentDirections.NegativeExtentDirection)
                extInput4.setOneSideExtent(extent_all_ne, adsk.fusion.ExtentDirections.NegativeExtentDirection)
                ext3 = cuts.add(extInput3)
                ext4 = cuts.add(extInput4)
9 REPLIES 9
Message 2 of 10
marshaltu
in reply to: Six1Seven1
It would be great if you can provide a runnable script to reproduce the issue. It is hard to judge what's wrong with the codes you posted.
I also took a look at the code sample you posted in another thread. Unfortunately I didn't reproduce the issue you mentioned. Instead I saw the error during creating second combined feature. It was because tool body "extrude_2" has been deleted during creating the first combined feature.
BTW: I did a minor change and commented red line out. All extent extrude would not work if there are no existing tool bodies in the design. Of course, the API "setDistanceExtent" and "setAllExtent" have been retired. We recommend to use new API "setOneSideExtent" and "setTwoSideExtent".
Marshal
#ucf-fusion-loader.
#Author-Harry Keen
#Description-Fusion360 addin to load and build ultimate CAD format json files.
import adsk.core, adsk.fusion, adsk.cam, traceback
#import system modules
import os, sys
#get the path of add-in
ADDIN_PATH = os.path.dirname(os.path.realpath(__file__))
#print(ADDIN_PATH)
#add the path to the searchable path collection
if not ADDIN_PATH in sys.path:
  sys.path.append(ADDIN_PATH)
import simplejson as json
IMPORT = ADDIN_PATH + "/template.json"
SKETCHES_LOC = ADDIN_PATH + "/sketches/"
def run(context):
  try:
    app = adsk.core.Application.get()
    # Get import manager
    importManager = app.importManager
    # Create a document.
    #doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    # Get the root component of the active design
    rootComp = design.rootComponent
    with open(IMPORT) as data_file:
      data = json.load(data_file)
    # print(json.dumps(data, sort_keys=True, indent=4 * ' '))
    # for n in data.keys():
    #   print(n)
    # print('-------')
    # for feature in data['features'].keys():
    #   print(data['features'][feature]['type'])
    # Import all sketches
    for sketch in data['sketches']:
      sketch_name = data['sketches'][sketch]['name']
      # Get dxf2d import options
      sketch_loc = SKETCHES_LOC + sketch_name + '.dxf'#'sketch_2.dxf'
      # returnValue = importManager_var.createDXF2DImportOptions(filename, planarEntity)
      dxf2dOptions = importManager.createDXF2DImportOptions(sketch_loc, rootComp.xYConstructionPlane)
      # Import dxf file to root component
      importManager.importToTarget(dxf2dOptions, rootComp)
      # Rename sketch
      for sketch in rootComp.sketches:
        if 'sketch' not in sketch.name:
          sketch.name = sketch_name
    # Extrude all extrusion features
    for feature in data['features']:
      feature = data['features'][feature]
      if feature['type'] == 'extrude':
        # Run extrude
        # Get base_sketch
          if sketch.name == feature['base_sketch']:
            base_sketch = sketch
            break
        # Get profiles
        # Create an object collection to use an input.
        profiles = adsk.core.ObjectCollection.create()
        # Add all of the profiles to the collection.
        for prof in base_sketch.profiles:
          profiles.add(prof)
        # Define Fusion type of extrude
        # Currently only going to use new_bodies and then combines to get any subtraction
        # Create extrusion input
        extrudes = rootComp.features.extrudeFeatures
        extInput = extrudes.createInput(profiles, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        # extInput = extrudes.createInput(profiles, adsk.fusion.FeatureOperations.JoinFeatureOperation)
        # Define distance of extrude
        distance = adsk.core.ValueInput.createByReal(feature['distance']/10)
        # Set the distance extent to be symmetric
        extInput.setDistanceExtent(True, distance)
        # Set the extrude to be a solid
        # extInput.isSolid = True
        # Set direction
        # extInput.setAllExtent(1)
        # Create the extrusion
        ext = extrudes.add(extInput)
        # Rename sketch
        for body in rootComp.bRepBodies:
          if 'extrude' not in body.name:
            body.name = feature['name']
    # Apply combines
      if feature['type'] == 'combine':
        # Define target_body
          if body.name == feature['solid_1']:
            target_body = body
        # Get tool_bodies
        tool_bodies = adsk.core.ObjectCollection.create()
        # Add all of the tool_bodies to the collection.
          if body.name == feature['solid_2']:
          #if feature['solid_2'] in body.name:
            tool_bodies.add(body)
        # Create combine input
        combines = rootComp.features.combineFeatures
        combInput = combines.createInput(target_body, tool_bodies)
        # Keep tool bodies
        combInput.isKeepToolBodies = False
        # Cut operation
        combInput.operation = adsk.fusion.FeatureOperations.CutFeatureOperation
        comb = combines.add(combInput)
        # Was going to rename but actually target body may have other combine features applied to it.
        # for body in rootComp.bRepBodies:
        #   if body.name == target_body.name:
        #     body.name = feature['name']
    # 28160 mm / 1108mm = 25.4 -> need to scale down to mm
  except:
    if ui:
      #print('Failed:\n{}'.format(traceback.format_exc()))
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Message 3 of 10
Six1Seven1
in reply to: marshaltu
Marshal,
Thanks for reply. Still not sure what you're saying. I don't see why the way I am doing this won't work.
It works with two of the cut extrusions. Then the last two circles to be cut, it fails.
# Global list to keep all event handlers in scope.
# This is only needed with Python.
handlers = []
def run(context):
    ui = None
    try:
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        buttonSample = cmdDefs.addButtonDefinition('MainButton','BM Addin Pro', 'This is an Addin for generating boxes','./Resources/Main Icons')
        # Connect to the command created event.
        MainButtonEvent = SampleCommandCreatedEventHandler()
        buttonSample.commandCreated.add(MainButtonEvent)
        handlers.append(MainButtonEvent)
        # Get the ADD-INS panel in the model workspace.
        addInsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        # Add the button to the bottom of the panel.
        buttonControl = addInsPanel.controls.addCommand(buttonSample)
        buttonControl.isPromoted = True
    except:
        if ui:
# Event handler for the commandCreated event.
class SampleCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            # Get the command
            cmd = eventArgs.command
            # Get the CommandInputs collection to create new command inputs.
            inputs = cmd.commandInputs
            #Add image input
            imageinput1 = inputs.addImageCommandInput('imageinput1','Diagram:','./Resources/Image Input/image main.png')
            # Create the value inputs
            length_in = inputs.addValueInput('length_in', 'Length','', adsk.core.ValueInput.createByReal(3))
            width_in = inputs.addValueInput('width_in','Width','',adsk.core.ValueInput.createByReal(2))
            thick_in = inputs.addValueInput('thick_in','Thickness','',adsk.core.ValueInput.createByReal(1))
            fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Fillets', False,'./Resources/Other Icons/fillet_32.png', True)
            fillet_in = inputs.addValueInput('fillet_in','Fillet Radius','',adsk.core.ValueInput.createByReal(0))
            hole_cb = inputs.addBoolValueInput('hole_cb','Add Hole Pattern', True,'', True)
            hole_dia = inputs.addValueInput('hole_dia','Hole Diameter','',adsk.core.ValueInput.createByReal(0))
            hole_spcX = inputs.addValueInput('hole_spcX','Hole Spacing in X','',adsk.core.ValueInput.createByReal(0))
            hole_spcY = inputs.addValueInput('hole_spcY','Hole Spacing in Y','',adsk.core.ValueInput.createByReal(0))
            inputChanged = inputChangedEvent()
            cmd.inputChanged.add(inputChanged)
            handlers.append(inputChanged)
            onExecute = SampleCommandExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
        except:
            if ui:
# Event handler for the execute event.
class SampleCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandEventArgs.cast(args)
            # Code to react to the event.
            ui.messageBox('In command execute event handler.')
            # Get the values from the command inputs.
            inputs = eventArgs.command.commandInputs
            width = inputs.itemById('width_in').value
            thickness = inputs.itemById('thick_in').value
            fillet = inputs.itemById('fillet_in').value
            filletcb = inputs.itemById('fillet_cb').value
            hole_dia = inputs.itemById('hole_dia').value
            hole_spcX = inputs.itemById('hole_spcX').value
            hole_spcY = inputs.itemById('hole_spcY').value
            holecb = inputs.itemById('hole_cb').value
            #call drawBox function and add input values
            drawBox(length, width, thickness, fillet, filletcb)
            holePat(hole_dia, hole_spcX, hole_spcY, holecb, length, width, thickness)
            #call addFillets function and add input value
        except:
            if ui:
def drawBox(length_in, width_in, thick_in, fillet_in, fillet_cb): #these values are item IDs - not variables (see above)
    try:
        # Get the active sketch.
        sketch = adsk.fusion.Sketch.cast(app.activeEditObject)
        # Get the root component of the active design.
        sketch1 = sketches.add(xyPlane)
        # Load the lines collection and draw geometry for BOX sketch (division for center around origin)
        Load_lines = sketch1.sketchCurves.sketchLines        #load the line API
        L1 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/-2), (width_in/-2), 0), adsk.core.Point3D.create((length_in/2),(width_in/-2), 0))
        L2 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/2),(width_in/-2),0), adsk.core.Point3D.create((length_in/2),(width_in/2),0))
        L3 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/2),(width_in/2),0), adsk.core.Point3D.create((length_in/-2),(width_in/2),0))                 #draw lines (start, end)
        L4 = Load_lines.addByTwoPoints(adsk.core.Point3D.create((length_in/-2),(width_in/2),0), adsk.core.Point3D.create((length_in/-2),(width_in/-2),0))
        #get sketch profile
        prof1 = sketch1.profiles.item(0)
        #Extrude thickness
        extrude1 = rootComp.features.extrudeFeatures
        extrude1_prof = extrude1.createInput(prof1,adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(thick_in)
        extrude1_prof.setDistanceExtent(False, distance)
        finish_extrude1 = extrude1.add(extrude1_prof)    #executes the extrusion
        if fillet_cb == True and fillet_in > 0:
            #fillets----------------------
            #find each Brep Edge
            extrude1_face0 = finish_extrude1.sideFaces.item(0) #endFace, sideFaces, startFaces etc
            get_loops0 = extrude1_face0.loops
            loop_0 = get_loops0.item(0) # 0 = closed loop, 1 = open
            load_edges = loop_0.edges
            brep_edge_0 = load_edges.item(3) #which edge on the face and loop
            extrude1_face1 = finish_extrude1.sideFaces.item(1)
            get_loops1 = extrude1_face1.loops
            loop_1 = get_loops1.item(0)
            load_edges = loop_1.edges
            brep_edge_1 = load_edges.item(3)
            extrude1_face2 = finish_extrude1.sideFaces.item(2)
            get_loops2 = extrude1_face2.loops
            loop_2 = get_loops2.item(0) #
            load_edges = loop_2.edges
            brep_edge_2 = load_edges.item(3)
            extrude1_face3 = finish_extrude1.sideFaces.item(3)
            get_loops3 = extrude1_face3.loops
            loop_3 = get_loops3.item(0)
            load_edges = loop_3.edges
            brep_edge_3 = load_edges.item(3)
            load_fillets = rootComp.features.filletFeatures
            # Create an edge collection, then add each found brep_edge
            edgeCollection0 = adsk.core.ObjectCollection.create()
            edgeCollection0.add(brep_edge_0)
            edgeCollection1 = adsk.core.ObjectCollection.create()
            edgeCollection1.add(brep_edge_1)
            edgeCollection2 = adsk.core.ObjectCollection.create()
            edgeCollection2.add(brep_edge_2)
            edgeCollection3 = adsk.core.ObjectCollection.create()
            edgeCollection3.add(brep_edge_3)
            #bring in the valueInput
            radius1 = adsk.core.ValueInput.createByReal(fillet_in)
            input1 = load_fillets.createInput()
            input1.addConstantRadiusEdgeSet(edgeCollection0, radius1, True)
            input1.isG2 = False
            input2 = load_fillets.createInput()
            input2.addConstantRadiusEdgeSet(edgeCollection1, radius1, True)
            input2.isG2 = False
            input3 = load_fillets.createInput()
            input3.addConstantRadiusEdgeSet(edgeCollection2, radius1, True)
            input3.isG2 = False
            input4 = load_fillets.createInput()
            input4.addConstantRadiusEdgeSet(edgeCollection3, radius1, True)
            input4.isG2 = False
            #execute the fillets
            fillet1 = load_fillets.add(input1)
            fillet2 = load_fillets.add(input2)
            fillet3 = load_fillets.add(input3)
            fillet4 = load_fillets.add(input4)
    except:
        if ui:
def holePat(hole_dia, hole_spcX, hole_spcY, hole_cb, length_in, width_in, thick_in): #these values are item IDs - not variables (see above)
    try:
            else:
            else:
    except:
            if ui:
class inputChangedEvent(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            changedInput = eventArgs.input
            fillet_in = None
            if changedInput.id == 'fillet_cb':
                inputs = eventArgs.firingEvent.sender.commandInputs
                fillet_in = inputs.itemById('fillet_in')
            # Change the visibility of the scale value input.
            if fillet_in:
                if changedInput.value == True:
                    fillet_in.isVisible = True
                else:
                    fillet_in.isVisible = False
        except:
            if ui:
def stop(context):
    try:
        #Delete Button Def
        buttonSample = ui.commandDefinitions.itemById('MainButton')
        if buttonSample:
            buttonSample.deleteMe()
        #Delete Button Control
        addinsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = addinsPanel.controls.itemById('MainButton')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
Message 4 of 10
marshaltu
Thank you for the sample codes. I can reproduce your issue. The root cause was you were trying to create two holes in same locations(circle3 in sketch2, circle3 in sketch3). The first hole was created successfully, but the second hole failed because we cannot find tool body to cut(it has been cut by the first hole).
What I understand is you want to create hole pattern in a block with specific length and width. It would be better to use RectangularPatternFeature to create those holes.
Marshal
    try:
            else:
            else:
                extInput3 = cuts.createInput(sketch3.profiles.item(0), adsk.fusion.FeatureOperations.CutFeatureOperation)
                extInput4 = cuts.createInput(sketch3.profiles.item(1), adsk.fusion.FeatureOperations.CutFeatureOperation)
    except:
            if ui:
Marshal Tu
Autodesk, Inc.
Message 5 of 10
Six1Seven1
Marshal,
You are a life saver. I guess I should be looking over my code a bit more clearly. Thanks for your help with this and I will use your rectangular pattern suggestion.
Regards
Message 6 of 10
Six1Seven1
Marshal,
I fixed the issue you mentioned, it still does not fix my issue. I have not tried the rectangular method yet, which confuses me still, even after looking at the rectangular pattern API sample.
Here is the fixed code and you will notice it still produces the same tool body creation error:
handlers = []
def run(context):
    ui = None
    try:
        buttonSample = cmdDefs.addButtonDefinition('MainButton','Plate Generator', 'An Add-in which generates a solid rectangle and applies holes or slots equidistant from part center.','./Resources/Main Icons')
    except:
        if ui:
    def __init__(self):
        super().__init__()
        try:
            # Get the command
            cmd.okButtonText = ("Generate") #text in "OK" button
            #Add image input
            imageinput1 = inputs.addImageCommandInput('imageinput1','Diagram:','./Resources/Image Input/Diagram/diagram.png')
            fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Corner Fillets', False,'./Resources/Image Input/Fillets', False)
#            onExecutePreview = MyExecutePreviewHandler()
#            cmd.executePreview.add(onExecutePreview)
#            handlers.append(onExecutePreview)
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
        except:
            if ui:
class MyExecutePreviewHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs.isValidResult
        except:
            if ui:
    try:
        #get sketch profile
        #Extrude thickness
            input1.isG2 = False
            input2.isG2 = False
            input3.isG2 = False
            input4.isG2 = False
            length_in.inputs
    except:
        if ui:
    try:
            else:
            else:
    except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
            fillet_in = None
            if fillet_in:
                else:
        except:
            if ui:
def stop(context):
    try:
        #Delete Button Def
        if buttonSample:
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
Message 7 of 10
marshaltu
I found a minor typo error(marked as red) in your codes. It worked well after correcting the error.
Marshal
    try:
            else:
            else:
    except:
            if ui:
Marshal Tu
Autodesk, Inc.
Message 8 of 10
Six1Seven1
Marshal,
Thanks for the reply. What is the typo? I have been using item numbers 0 and 1 with success. I am currently resorting to the rectangular pattern method you suggested. But still curious what is wrong here.
Message 9 of 10
marshaltu
Sorry, I thought you can easily find the issue. The original code line was as below. You used the first profile of sketch2 though you defined sketch3. So I changed it from sketch2 to sketch3.
Marshal
Marshal Tu
Autodesk, Inc.
Message 10 of 10
Six1Seven1
I see what you are saying now. Thank you very much.
Regards
