Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
'Generate Face Groups' via python script?
8 REPLIES 8
Message 1 of 9
ferdlhons
280 Views, 8 Replies
I have imported a simple 3d-mesh (obj-File) and I'm wondering if it possible to do a 'Generate Face Groups' via script?
In the end I need the edges of each FG afterwards... (seems to me similar to the BRepEdges - stuff, but I don't know how to generate them). I'm new to the fusion API, so many thnx for any help!!
BR gerhard
8 REPLIES 8
Message 2 of 9
ferdlhons
in reply to: ferdlhons
Seems my question cannot be answered, maybe the API function which I asked for is not available?
Is there another way to create a BRep from a Mesh and then access the BRepEdges?
Thnx for any help...
Message 3 of 9
Hi I'm sure there is a solution that at least comes close. Not all features need to be accessible through the Fusion API but that doesn't have to stop you right away.
A first option would be to use 3rd party libraries (for example PyAutoGui) and simulate the user clicking on the "Generate Face Groups" button.
The second option would be to find the command directly through adsk.core.Application.userInterface and run it with the execute.
Message 4 of 9
Hi Tomas,
many thnx for your reply. For me it is not the big problem not having the 'Generate Face Groups' function (your PyAutoGui is a great idea anyway). Sorry my missleading info:
My problem is: I need the DATA of the face groups itself (or BRepEdge data). I don't know how to access it via python script... I tried to acess via
design.rootComponent.bRepBodies
but those seem to be empty. How do I create them from a mesh?
Message 5 of 9
Mesh body cannot be found among BRepBodies because Mesh are not BRep from the definition of these objects.. You need to convert Mesh to BRep first and then the converted body will be available from BRepBodies.
Message 6 of 9
Thank you very much - I think this helps 🙂
Message 7 of 9
kandennti
Hi @ferdlhons -San.
We have created a sample script that executes 'Generate Face Groups' using the text command.
After running the script, select MeshBody.
# Fusion360API Python script
import traceback
import adsk.core as core
import math
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = "Select MeshBody"
        selFilter: str = "MeshBodies"
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        exec_mesh_calculate_faceGroups_Command(5.0, 0.1)
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def exec_mesh_calculate_faceGroups_Command(
        infoOpeningAngle: float = 25.0,
        infoFastSegmentArea: float = 0.2,
    cmds = [
        u"Commands.Start ParaMeshCalculateFaceGroupsCommand",
        u"Commands.SetString infoSegmentationMethod {}".format(
            "infoSegmentationMethodFast"
        u"Commands.SetDouble infoOpeningAngle {}".format(
            math.radians(infoOpeningAngle)
        u"Commands.SetDouble infoFastSegmentArea {}".format(
            infoFastSegmentArea
        u"NuCommands.CommitCmd",
    [app.executeTextCommand(cmd) for cmd in cmds]
def select_ent(
    msg: str,
    filter: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filter)
        return sel
    except:
        return None
Message 8 of 9
kandennti
in reply to: kandennti
@ferdlhons -San.
I have created a script to create a sketch of the FaceGroup boundary.
Note that this is a very slow process.
import traceback
import adsk
import adsk.fusion as fusion
import math
def run(context):
    try:
        des: fusion.Design = app.activeProduct
        des.designType = fusion.DesignTypes.ParametricDesignType
        # select mesh
        if not sel: return
        baseMesh: fusion.MeshBody = sel.entity
        # face group
        exec_mesh_calculate_faceGroups_Command(baseMesh, 5.0, 0.1)
        # mesh extract
        meshes = exec_mesh_extract(baseMesh)
        # mesh to brep
        breps = meshes_to_brepBodies(meshes)
        # open edges
        openEdgesLst = get_open_edges_by_bodies(breps)
        # draw edges - sketch
        comp: fusion.Component = baseMesh.parentComponent
        draw_edges_by_edgesList(comp, openEdgesLst)
        # remove
        [x.deleteMe() for x in meshes]
        breps[0].deleteMe()
        baseMesh.isLightBulbOn = True
    except:
        if ui:
def draw_edges_by_edgesList(
        comp: fusion.Component,
        edgesLst: list[list[fusion.BRepEdge]],
) -> list[fusion.Sketch]:
    sktLst = []
    for edges in edgesLst:
        sktLst.append(
            draw_edges(comp, edges)
        adsk.doEvents()
    return sktLst
def draw_edges(
        edges: list[fusion.BRepEdge],
) -> fusion.Sketch:
    if len(edges) < 1: return
    skt: fusion.Sketch = comp.sketches.add(
        comp.xYConstructionPlane
    skt.name = "Mesh Group Open Edge"
    objs: core.ObjectCollection = core.ObjectCollection.createWithArray(
        edges
    for x in edges:
        if not x.classType() == fusion.SketchLine.classType():
            print("K")
        else:
            print("V")
    skt.isComputeDeferred = True
    skt.include(objs)
    skt.isComputeDeferred = False
    for crv in skt.sketchCurves:
        crv.isReference = False
        crv.isFixed = True
def get_open_edges_by_bodies(
        bodies: list[fusion.BRepBody],
) -> list[list[fusion.BRepEdge]]:
    openEdgesLst = []
    for body in bodies:
        openEdgesLst.append(
            [e for e in body.edges if e.coEdges.count < 2]
    return openEdgesLst
def meshes_to_brepBodies(
        meshes: list[fusion.MeshBody],
) -> list[fusion.BRepBody]:
    if not meshes: return
    if len(meshes) < 1: return
    comp: fusion.Component = meshes[0].parentComponent
    beforeLst = list(comp.bRepBodies)
    sels: core.Selections = app.userInterface.activeSelections
    sels.clear()
    [sels.add(m) for m in meshes]
    cmds = [
        u"Commands.Start ParaMeshConvertCommand",
        u"Commands.SetString ConvertMeshInfoOperation {}".format(
            "infoOperationNewBaseFeature"
        u"Commands.SetString MeshToBREPAlgorithmInput {}".format(
            "infoMethodTriangleBased"
    return [m for m in comp.bRepBodies if not m in beforeLst]
def exec_mesh_extract(
        mesh: fusion.MeshBody,
) -> list[fusion.MeshBody]:
    if not mesh: return
    comp: fusion.Component = mesh.parentComponent
    beforeLst = list(comp.meshBodies)
    sels.clear()
    sels.add(mesh)
    cmds = [
        u"Commands.Start ParaMeshExtractCommand",
        u"Commands.SetString infoType {}".format(
            "infoTypeAllFaceGroups"
        u"Commands.SetBool infoPreserveSourceBody 1",
    return [m for m in comp.meshBodies if not m in beforeLst]
    sels.clear()
    sels.add(mesh)
    cmds = [
            infoFastSegmentArea
def select_ent(
    msg: str,
    filter: str
    try:
        return sel
    except:
        return None
Message 9 of 9
ferdlhons
Hello Kandennti-San,
this is amazing - for me as newby this is very helpful lession how to get access to the data! Thank you so much for this, I will try this today evening...
BR Gerhard
