Fusion360Image2Surface
adresa_de_legatura
adresa_de_legatura
Hi, I have a problem with Image2Surface addin.I install it from github, i open it from the add-in menu and tried to open an image. I made the mistake to open a mig image and of course the app froze.I had to loggof from Fusion 360 and logon again.But now every time i open the app from the add-in menu i get only a white window with a "close" button at the bottom of the window.The close button work and i can close the app but this is all i can do.I tried to unistall and install the app again but still doesnt work.Did somebody got the same issue from this app and did you solve it?
Thank you.
adresa_de_legatura
Update to what i daid before.After i close the app window i have to stop it from running in the background, but  after i click the Stop button from Scripts and Addins i get this error:
Failed
Traceback(most recent call last):
File "C:/users/..../API/Addins/Image2Surface/Image2Surface.py, line 208, in stop palette.delete.Me()
File "C:/users/..../Appdata/Local/Autodesk/webdeploy/production/......./Api/Python/packages\adsk\core.py in line 11287 in delete.Me return _core.Palette(self)
RuntimeError 3: Cannot delete native palette.
I tried Github too but the app is 2 years old without no updates.
BrianEkins
It would be best to directly contact the author of the program.  I don't know if he watches this forum.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
