Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion360 error during installation
15 REPLIES 15
Message 1 of 16
jurisevickg
406 Views, 15 Replies
I can not install Fusion360 for several days.
It's a clean installation, w/o any Autodesk software installed.
I have the Unable to connect to the network error.
When I run the Autodesk Licensing support tool, I get next:
I do not use any proxies, VPN, or anything.
Any solution?
Thank you
15 REPLIES 15
Message 2 of 16
dooyoul_chung
in reply to: jurisevickg
Message 3 of 16
jurisevickg
Please find it attached.
Also, I found this site that explain why the api.autodesk.com is not accessible...
https://resources.imaginit.com/support-blog/autodesk-licensing-url-api-autodesk-com-is-inaccessible
Message 4 of 16
dooyoul_chung
Thank you.
It would be helped if you can share installation log file.
Thanks.
Installation Log files:
For installation or update errors.
  • Windows: C:\Users\(username)\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
    macOS: Macintosh HD>Users>(username)>Library>Logs>autodesk.webdeploy.streamer.log
Message 5 of 16
jurisevickg
Find it attached.
Just to mention that I have two agents from Autodesk support remotely connected to the PC, and couldn't fix the problem.
Message 6 of 16
dooyoul_chung
Hi @jurisevickg
While we investigate further you case, can you set environment variable and value with below command line then try again to installation?
setx SKIP_PRECHECK "1"
If installation success, then please don't forget to set back environment variable with below command line option.
setx SKIP_PRECHECK ""
Message 7 of 16
jurisevickg
User or system variable?
I even tried to change in precheck_config.json:
"CheckNetworkConnectivity" :
"url" : "https://knowledge.autodesk.com/article/Precheck-Network-Connectivity-issue-Fusion-360",
"mandatory": "Yes"
to No, but installation freeze.
Message 8 of 16
dooyoul_chung
Hi @jurisevickg
Please set System variable. This option would pass precheck steps.
Thanks.
Message 9 of 16
jurisevickg
Same error.
Message 10 of 16
dooyoul_chung
I see that your error happened while checking network connectivity from you shared log file. Which is one of precheck steps.
Let me clarify skip precheck steps:
1. open "CMD"
2. setx  SKIP_PRECHECK "1"
3. cd %userprofile%\downloads
4. call "Fusion 360 Client Downloader.exe"
Thanks.
Message 11 of 16
jurisevickg
Ok, tried that one. Different error - see the snip. And the log in attach
Message 12 of 16
dooyoul_chung
Hi @jurisevickg
Thanks for sharing.
Quick check: Are you able to access below URL?
Message 13 of 16
jurisevickg
Does this counts as able to access?
Message 14 of 16
dooyoul_chung
Message 15 of 16
jurisevickg
OMG! Second topic worked! Since I am from Serbia, I will copy-paste the solution from the second link that you provided in the last post:
"I immediately realized that this is a problem since I'm from Serbia and I have installed on my notebook software for reading Serbian ID cards. It seems that like everything in this country certificates issued by Ministry of Internal Affairs are messed up
Solution was to open certmgr search for MUP and delete all their certificates. As soon as I did this Fusion 360 installed like charm.
I hope this will help some of you."
Thank you so much on your great support!
Message 16 of 16
dooyoul_chung
Hi @jurisevickg
Glad that the solution works for you. Thank you for your feedback and accept solution would help for future similar user cases.
