Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion error report
7 REPLIES 7
Message 1 of 8
umairnaeem139
383 Views, 7 Replies
Fusion error report
I keep getting the Fusion error message every time I try to open it. Can someone help me out here? I tried turning off the antivirus and firewall but that didn't work.
7 REPLIES 7
Message 2 of 8
@umairnaeem139 When you send in this crash report to Autodesk it will generate a report ID. Can you post that ID here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
777942112
Message 4 of 8
@umairnaeem139 Thank you for the report ID. Can you please follow the below article for the solution.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-crashes-on-...
Autodesk Fusion
Join Fusion Insider
Message 5 of 8
I currently do not have Ansys installed on my computer so I'm not sure the given article would help. I visited the link that you provided but this has nothing to do with the error I am getting I believe since I do not have Ansys at the moment. Any other way to resolve this issue?
Message 6 of 8
@umairnaeem139 Did you run ANSYS on your machine at any time? This certainly looks to be crashes with the same symptom.
Autodesk Fusion
Join Fusion Insider
Message 7 of 8
  1. Yes, I did run ANSYS once. The 2024 version. But it was causing some issues. The domains like structural, electric, vibrational, Fluent etc were not visible so I uninstall led ansys
Message 8 of 8
@umairnaeem139 There is something left behind that is causing this crash. Can you please go to the section limitation https://ansyshelp.ansys.com/public/account/secured?returnurl=//////Views/Secured/corp/v242/en/ref_ca... in this page and see if you can make any of this change on your machine?
Autodesk Fusion
Join Fusion Insider
