Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion Crash w/o error reporting - progress dialog?
3 REPLIES 3
imajar
205 Views, 3 Replies
Using the sample code below, I am crashing fusion at iteration 349 - no error reporing, no traceback, fusion just disappears.  Does anyone else see this?  My system is Win 10, core i7-6700K, Nvidia M4000, 64 GB Ram.
(This sample code is part of a larger code that is processing thousands files, that code was reliably crashing every 349 iterations and I boiled it down to this little tidbit).
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        documents=app.documents
        progressdialog=ui.createProgressDialog()
        progressmessage="CleaningFiles . . . %v of %m, %p% Complete"
        progressdialog.show("Progress Dialog Complete", progressmessage,0,500)
        adsk.doEvents()
        for k in range(0,500):
            # progressdialog.progressValue=k
            newDoc=documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
            newDoc.close(False)
            print("Iteration {}".format(k))
        progressdialog.hide()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks in advance,
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
3 REPLIES 3
xapo9966
in reply to: imajar
I've tried your code and got 413 iterations on my i7-8700 CPU with only 16GB RAM. Memory consumption was growing during the code execution. It reached cca 70% just before the crash. I can only guess there are some memory limitations either in python or C++ api.  I would suggest to try the same code in C++.
chris
imajar
in reply to: xapo9966
I'll have to give that a try.
Something interesting I could have mentioned in the first post is that If I comment out the progress dialog, that script will finish the 500 iterations.
Aaron Jarrett, PE
LinkedIn
Life is Good.
goyals
in reply to: imajar
Thank you for reporting it. We will take a look at it.
Shyam Goyal
Sr. Software Dev. Manager
