Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion CAM recognizeHoleGroups API
2 REPLIES 2
karolis.s
104 Views, 2 Replies
I want to report an issue with the method below
hole_groups :adsk.cam.RecognizedHoleGroups = adsk.cam.RecognizedHoleGroup.recognizeHoleGroups(body)
It return a single hole group for holes with different axis directions:
I think the problem is that the script thinks that these holes are through and that's why they are grouped. While in workflow I must create 2 separate operations for each side of the panel.
2 REPLIES 2
karolis.s
in reply to: karolis.s
Forgot to add a sample file for debugging.
Seems like a bug to me I will report this to the team
Boopathi Sivakumar
Senior Technology Consultant
