Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion CAM API Failed to set up stock body
1 REPLY 1
karolis.s
123 Views, 1 Reply
Hello, I am creating a stock for parts in API. The simplest way to do this is to create a new body and use it as a stock.
Here is my code:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = Doc()
        setups = doc.cam.setups
        # Create a SetupsInput object to define a milling setup.
        setupInput = setups.createInput(adsk.cam.OperationTypes.MillingOperation)
        setupInput.models = [doc.body]
        setupInput.name = 'TestSolidSelect'
        stockModeParam = setupInput.parameters.itemByName('job_stockMode')
        stockModeParam.expression = '\'solid\''
        stockSolidParam: adsk.cam.CadObjectParameterValue = setupInput.parameters.itemByName('job_stockSolid')
        stockSolid = doc.cam.designRootOccurrence.bRepBodies[1]
        stockSolidParam.value = [stockSolid]
        setup = setups.add(setupInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class Doc:
    def __init__(self):
        productType = app.activeProduct.productType
        # root component
        self.rootC = None
        self.body: adsk.fusion.BRepBody = None
        if productType == 'CAMProductType':
            cam: adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
            camOcc = cam.designRootOccurrence
            self.rootC = camOcc.component
            self.body = camOcc.bRepBodies[0]
            self.cam: adsk.cam.CAM = cam
        elif productType == 'DesignProductType':
            design = app.activeProduct
            self.rootC = design.rootComponent
            self.body = self.rootC.bRepBodies.item(0)
        if self.rootC == None or self.body == None:
            ui.messageBox('Active product is not Design or CAM product')
            return
Here is the error I get:
I tried all the combinations that came to my mind. Any ideas?
1 REPLY 1
kandennti
in reply to: karolis.s
Hi @karolis.s -San.
Try this.
        stockSolidParam.value.value = [stockSolid]
