Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion API messagebox mismatch between Windows & macOS
2 REPLIES 2
scottmoyse
173 Views, 2 Replies
The messageBox method in the Fusion 360 API allows us to pass in a message box title. This works great on Windows. But on macOS it doesn't appear... it's a pretty useful feature since you can include your add-in name in the title so the user always knows where the messagebox has come from. Is it possible to get this fixed in the API?
I've noticed that the filedialog.filter chops of the filter info between the ()'s as well. Where as it gets displayed in Windows so the user knows which file types are going to be filtered.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
2 REPLIES 2
JeromeBriot
in reply to: scottmoyse
scottmoyse
in reply to: JeromeBriot
Thanks... the file type drop-down issue wasn't reported there though. I'll create a new post for that one instead of the after thought above.
Kind Regards
Scott Moyse
Manufacturing Technical Specialist Autodesk Expert Elite
P: +64 9 302 4028 M: +64 21 055 7775
scott.m@cadpro.co.nz
CADPRO Systems Ltd
Auckland - 527b Rosebank Road, Avondale Auckland
Christchurch - Unit 3, Kendal Avenue, Burnside
New Zealand
Scott Moyse
