Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 to UGS Failed to post
2 REPLIES 2
kulpio
201 Views, 2 Replies
Hi everyone,
I am trying to get UGS Plugin to work with Fusion 360. I did everything I had to do to install the plugin (which is in my F360 plugin library) and followed the instruction on the Post to UGS pop up window.
However, I get the following error (screenshot attached).
Would anyone have an idea on how to get it to work, or what I did wrong?Also attached my "Post to UGS" pop up settings.
My CNC machine is a Shapeoko3 XL
I run on Mac
F360 has the latest update.
2 REPLIES 2
kulpio
in reply to: kulpio
So I found the issue. It was my path for the UGS which should not include "Macintosh HD" for some reason.
However now I get the following errors in UGS when I run the job:
An error was detected while sending 'T5M6': (error:20) Unsupported or invalid g-code command found in block. Streaming has been paused.
So why is it creating invalid g-code?
Should I insert my tool library into UGS as well so it supports them?
... very confused and not very good at this.
BrianEkins
in reply to: kulpio
It's best to ask the developer of the add-in.  No one here has any detailed information about specific add-ins.  This forum is for general questions about the Fusion 360 programming interface, not the add-ins that use it.
Brian Ekins
