Fusion 360 Python Script Problem - Add Folder Name To Output
isocam
isocam
Can anybody help???
Please see the attached ".txt" file (I have changed the file extension from .py to .txt)
I can run the script on an assembly document OK.
All I need to do is to add the document's folder name to the output file (shown in the script file as ??????????)
For example,
I have a main project file where all my documents (assemblies, parts & drawings are stored)
I also have two other folders "Purchased Parts" & "Referenced Parts". Please see the attached picture.
I need to update the script file to show the folder name where the document has been inserted into the assembly.
In the example, show above, this could be "Purchased Parts" & "Referenced Parts".
Can anybody update the script for me to allow me to add the folder name to the output?
Many thanks in advance!
Darren
Rushikesh.kadam
@isocam one can use DataFile.childReferences property to get a list of referenced designs. You can loop through the list to get the details like file name, folder name, project name etc.
Below is a sample script to output the details of external references in a file.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        document = design.parentDocument.dataFile
        info = "\n"
        for external_ref in document.childReferences:
            info += f'\n File name: {external_ref.name}'
            info += f'\n Folder name: {external_ref.parentFolder.name}'
            info += f'\n Project name: {external_ref.parentProject.name}'
            info += "\n-----------------------------------"
        app.log(info)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
