Announcements
Fusion 360 Parts list / BOM data
I have created a parametric kitchen cabinet design.  The cabinet consists of 5 extruded rectangles.  I tried the extract bom script, and would like to add length, width and thickness for each part.  How do I refernce the dimensions to modify the script?
drew
Replying because I am also struggling to make the BOM feature useful for getting actual measurements of parts.
For my current woodworking project (a stage set that is a center balcony and two staircases hinged to that balcony) I have had to do the following:
1) Get the plug-in called BOM-CSV. Its available as on May/June 2017 in the Fusion plug-in pages.
2) Export the BOM using that plugin, not the native BOM tool. It will create a CSV file where you tell it to.
    All the items, measurements, and info about them will be in one column, except for the material which appears in its own column for some reason.
    This isn't useful as it is, so you need to edit the CSV file to create new columns and replace unnecessary information in the CSV's second column.
3) Open in Notepad or equivalent.
     ADD "," two times after the heading "Dimension" (this prepares for replacing the many " x " entries, keeping the columns consistent)
     FIND/REPLACE all instances of ";" with ","
     FIND/REPLACE all instances of " x " with ","
     FIND/REPLACE all instances of any other extraneous data with null.
4) Open the CSV file in Excel.
     You should now see a 6-column spreadsheet. May have weird extra stuff at the top. Delete that weird stuff - in my case it was leftovers from the text editor.
     The dimensions will be in columns C, D and E - but they are not in size order (smallest to largest dimension, as would be needed to create cutlists)
     Excel won't do this type of sorting in its normal "sort" interface, so it is formula time!
     In columns G, H, and I create the sorting formulas for rearranging these values without re-sorting the entire spreadsheet.
         Cell G2 gets  =SMALL($C1:$E1,1)    Cell H2 gets  =SMALL($C1:$E1,2)   Cell I2 gets  =SMALL($C1:$E1,3)
         Pull-down the formula to the bottom of your data, on each column.
    Now copy the cell range created by the formulas and paste the VALUES back into the original cells. Don't just paste - that'll be no fun.
    You can delete columns G, H, and I now if you want.
    Next sort by material, size, or other criteria you personally need to sort by - using Excel's plain vanilla sort interface.
What you have now is a sheet with everything sorted and with the size numbers appearing lowest to highest, left to right.
But wait - you will also have a bunch of stuff that doesn't make sense - any of your non-rectangular and non-right-angle to origin planes components.
Some of these are easy - use the BOM data to calculate the hypotenuse for any parts that merely sit at an angle to ONE origin plane.
But as to the rest - if the part sits at an angle to MORE THAN ONE origin plane, or if the part is shaped such that it's Fusion bounding box doesn't reflect the real measures of the part - Ha ha.
Been hunting for almost a week here and there on Google and of course in this community.
Have not found a way to resolve getting Fusion to supply a list of REAL MEASURES on parts, not bounding box measures.
Hope anyone else finding this can at least make headway with the method I describe.
Please PM me if you figure out how to export actual measures instead of bounding boxes.
ekinsb
Getting the true size of a part is not particularly easy.  I've written a blog post that discusses some of the issues and describes one solution. This doesn't have anything to do with the BOM side but is one piece of the puzzle.
http://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html
Brian Ekins
Mod the Machine blog
drew
Hi Brian-
Can you please take a look at a related post I have made in the API section of the community?
https://forums.autodesk.com/t5/api-and-scripts/programmatically-access-dimensions-of-parts-by-pullin...
This issue of not getting actual part sizes is a serious problem for those of us that need to get that data out of Fusion into a reliable and usable list of parts with sizes.
(Some of us still use actual human-controlled tools and not CNC machines to fabricate!)
A vent/rant:
BOM stands for Bill Of MATERIALS.
Why the heck the coders that wrote the BOM tool used the bounding box is just beyond me... Because as you discuss in that blog post- the bounding box has little to do with any MATERIALS, and everything to do with being a container for ALL SORTS of stuff. And with it being 'trapped' on the origin XYZ planes it seems even worse a choice...
So - please take a look at my idea there in that other post. I would be very happy to hear/read you think through whether it is feasible.
ekinsb
I know this doesn't help you but I just wanted to give you some background on the utilities you see in the "Scripts and Add-Ins" dialog.  All of those were written as programming samples to demonstrate various aspects of the programming interface.  The BOM sample was written to illustrate iterating through an assembly and extracting some information. There wasn't an attempt to design a full featured command.  The same is true for the other samples and some are more useful in regular workflows than others.  But, as I said in my last post, there is a lot of functionality provided by the API so it would be possible for someone to write a more full featured BOM exporter.  Unfortunately Fusion itself is also currently very weak in this area.
Brian Ekins
