Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 Palette - Mimimal Select element doesn't work on Mac
4 REPLIES 4
511 Views, 4 Replies
@goyals @kris_berg
I am developing a Fusion 360 C++ Add-in . It is based on this example:https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F0068478-49F0-4E5E-9BAD-3116D8FCBCAF
My add-in opens up a Palette that displays a Web-page. The problem I am having is 'select'  html option doesn't work in Fusion 360 (Mac) version. On Windows it works fine.
To create a minimal code that reproduces the problem I created a html page with just the "select" html element as seen below
<!DOCTYPE html>
<html>
<body>
<h1>The select element</h1>
<p>The select element is used to create a drop-down list:</p>
<label for="cars">Choose a car:</label>
<select id="cars">
  <option value="volvo">Volvo</option>
  <option value="saab">Saab</option>
  <option value="opel">Opel</option>
  <option value="audi">Audi</option>
</select>
<button type="button" onclick="alert('Hello world!')">Click Me!</button>
</body>
</html>
When I try to select the car, all options show for a split second and I can't pick any other option.
The code works fine on Windows. The HTML page on its own renders and functions as expected on Windows and Mac in all major browsers - Just not in palette of Fusion 360 on Mac.
I am looking for suggestions how to resolve this.
4 REPLIES 4
JeromeBriot
To fix this issue, set useNewWebBrowser to True in the palettes.add method:
palette = palettes->add("myPalette", "My Palette", "palette.html", true, true, true, 300, 200, true);
goyals
I opened the web page you shared in palette and it works fine for me. I use old browser while creating palette control. Please take a look at the video attached. Thanks.
Shyam Goyal
Shyam Goyal
Sr. Software Dev. Manager
JeromeBriot
in reply to: goyals
in reply to: JeromeBriot
Thanks for the video. I was getting the same behavior and I was able to get it to work by passing optional 'true' (for enabling use of new browser engine) parameter to _palette->add() function.
I hope it saves someone else's time.
Technology Administrators
