Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 crashes
2 REPLIES 2
293 Views, 2 Replies
Fusion 360 crashes
When updating an assembly change in another assembly FUSION craches.
2 REPLIES 2
ekinsb
This is the "Fusion 360 API and Scripts" forum.  Are you using the API when the crash occurs or are you using Fusion interactively?  If you're not using the API you might want your ask your question in the general Fusion 360 Design forum.
Brian Ekins
Mod the Machine blog
in reply to: ekinsb
Thanks for the heads up. I'll post it on the design forum.
