Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 API Reference manual for offline viewing
9 REPLIES 9
Message 1 of 10
3984 Views, 9 Replies
Can Fusion 360 API Reference manual be made available in .chm for offline viewing? Or some similar format...
9 REPLIES 9
Message 2 of 10
ekinsb
Here's a link to a chm version of the help.  Hopefully it will help.  To get it to work correctly you'll probably need to access the Properties dialog for the file and click the "Unblock" button, as shown below.  The file works fine on Windows and there are chm viewers for Mac but I haven't tried them.
Brian Ekins
Mod the Machine blog
Message 3 of 10
in reply to: ekinsb
Thanks a lot. Will be of great help.
Message 4 of 10
soswow
 Is there way to get some other, more multi-OS format like PDF? I tried to convert chm but with no luck =( using online multi-iframe browesing so painfull =(
Message 5 of 10
ekinsb
in reply to: soswow
The primary format for publishing the help is the online version.  The fact that the chm is available is just by luck.  The same help system that is used to product the help for Inventor was enhanced to also allow it to be used for Fusion's help.  Inventor requires a chm file so we end up getting that for free and weren't using it at all until I posted it here.  To do some other format would likely require quite a bit of work which I don't anticipate happening anytime in the near future.
Brian Ekins
Message 6 of 10
ekinsb
in reply to: ekinsb
I've posted a new version of the API help that corresponds with the Fusion update that went out this past weekend (Nov. 15, 2015).  The link is the same as in my initial response.
Brian Ekins
Message 7 of 10
Cotral.RD2
in reply to: ekinsb
@ekinsb The Link you provided doesnt seem to work anymore. can you update it ?
Pavan HEMMEGE VENKATAPPA
Fusion 360 Ultimate User
Message 8 of 10
BrianEkins
in reply to: Cotral.RD2
I want to update this post.  The original link doesn't work because the location it references no longer exists.  I've since made the chm available directly on my website.
Brian Ekins
Message 9 of 10
rodwyll
in reply to: BrianEkins
Thank you very much for making this available.
Message 10 of 10
BrianEkins
in reply to: rodwyll
Here's another update.  The chm file is now updated and made available for each Fusion 360 release.  The link is on the "Welcome to the Fusion 360 API" help page, as shown below, and here a direct link to download the chm.
Brian Ekins
