Fusion 360 API move body
n.michiels
n.michiels
Hello All,
I have a specific question.
I have a .step file of an assembly. I convert all the bodies to components. What happens is that the origin of each component is in the center of the assembly. What I want to do is move the bodies in such a way that the origin is in the middle of the component. After moving the body, I place the component back in its original position.
nmichiels_0-1726126968535.png--> nmichiels_1-1726127011600.png-->
This works with the code I have, but I want to do this for each component, and this is where it goes wrong.
After I do the first one, where it succeeds, I move on to the second one, which also works, but at that moment, the first one moves back to the origin of the assembly.
elif action == 'repairDuplicates':
                occs = rootComp.allOccurrences
                # get the first occ out od data and find it by name
                item = data[0]
                data.pop(0)
                occ_base = occs.itemByName(item)
                # get the matrix from the occ
                matrix3d_base = occ_base.transform2
                position = matrix3d_base.translation
                ref_coord = np.array(position.asArray()) # this is its original position
                # get the boundingbox points of the body inside the occurence
                occ_base_body = occ_base.bRepBodies.item(0)
                body_bb = np.array([
                    [occ_base_body.boundingBox.minPoint.x, occ_base_body.boundingBox.minPoint.y, occ_base_body.boundingBox.minPoint.z],
                    [occ_base_body.boundingBox.maxPoint.x, occ_base_body.boundingBox.maxPoint.y, occ_base_body.boundingBox.maxPoint.z]
                # calculate the midpoint of the body and the displacement that is needed
                midpoint_1 = (body_bb[0] + body_bb[1]) / 2
                displacement = ref_coord - midpoint_1
                # now I add the body to a collection so we can do the move later.
                bodies = adsk.core.ObjectCollection.create()
                bodies.add(occ_base_body)
                # Define a matrix that will move the body.
                vector_body_move_to_origin = adsk.core.Vector3D.create(displacement[0], displacement[1], displacement[2])
                transform_body = adsk.core.Matrix3D.create()
                transform_body.translation = vector_body_move_to_origin
                # Create a move feature
                moveFeats = rootComp.features.moveFeatures
                moveFeatureInput = moveFeats.createInput2(bodies)
                moveFeatureInput.defineAsFreeMove(transform_body)
                moveFeats.add(moveFeatureInput)
                # Define a matrix that will move the occurrence to its original position
                vector = adsk.core.Vector3D.create(midpoint_1[0], midpoint_1[1], midpoint_1[2])
                mat: adsk.core.Matrix3D = matrix3d_base
                mat.translation = vector
                occ_base.transform2 = mat
Thank you!
Nick
Jorge_Jaramillo
I believe you might need to call design.snapshots.add() everytime you move an occurrence to keep it in place.
Jorge Jaramillo
n.michiels
Hello Jorge,
Thank you very much (again 😀 ), that did the trick.
