Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 API: How to select a component with no command dialogue?
1 REPLY 1
mntruell
136 Views, 1 Reply
The Xometry Fusion 360 plugin allows the user to select a component without seeing a command dialogue -- instead, the user only interacts with a palette.
How can I replicate this functionality in my own Add-in? I can't figure out how to do this with commands, because it doesn't look like you cannot create a selection command input without showing the user a dialogue.
1 REPLY 1
Hi @mntruell
you can use ui.selectEntity
selItem = ui.selectEntity("select the component","Occurrences")
Here is the documentation https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c05f97b8-9c8f-404b-8b21-f170d194ef8e
This will allow to select an entity without any ui
Boopathi Sivakumar
Senior Technology Consultant
