Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Fusion 360 API equivalent for "Get Latest Version"
3 REPLIES 3
tomveuskens
175 Views, 3 Replies
Hello everyone
Does anyone know if there is an equivalent in the API to refresh a design once it has been updated by a different Fusion instance? Similar to clicking the "Get Latest Version" button?
Thank you!
3 REPLIES 3
kandennti
in reply to: tomveuskens
tomveuskens
in reply to: kandennti
Dear @kandennti
Thank you for getting back to me.
The Document.updateAllReferences method consistently triggers
RuntimeError: 3: update all references not allowed on this document
for me.
The text command you referred to, however, works perfectly.
Thank you very much.
All the best
Tom
en9y37
Hi @tomveuskens
That happened to me too. The point is that if the document doesn't need an update, you will get that error. So, to avoid it, you only have to add this condition:
    design = adsk.fusion.Design.cast(app.activeProduct)
    if not design.parentDocument.isUpToDate:
        design.parentDocument.updateAllReferences()
I hope it helps
