Float slieder command input value format
Is it possible to display only 1 digit after comma instead of 3 (for example 12.2 mm instead of 12.200 mm)?
goyals
Preferences in fusion control the number of decimal places. If you go to preferences and then 'Unit and Value Display->General Precision' then you can set it to one decimal place. It is not exposed through API so all commands in Fusion display information consistently.
Shyam Goyal
Sr. Software Dev. Manager
