Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Finding Child Components
2 REPLIES 2
nnamfoh
664 Views, 2 Replies
I need to access the child components of a component (often the root component). I need to create an object collection of all bodies in the parent and its children to edit the groups
2 REPLIES 2
marshaltu
in reply to: nnamfoh
The following script would demo how to get all bodies under root. Please let us know if you have other questions.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        componentNameMap = {}
        componentNameMap[root.name] = root
        for occ in root.allOccurrences:
            subComp = occ.component
            componentNameMap[subComp.name] = subComp
        allbodies = adsk.core.ObjectCollection.create()
        for comp in list(componentNameMap.values()):
            for body in comp.bRepBodies:
                allbodies.add(body)
        ui.messageBox("Total {} bodies under root component".format(allbodies.count))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
hammadedesigns
in reply to: marshaltu
What am I supposed to do with this root?  I am new to Fusion 360 and really need to see the children of a feature so I know what may change or have issues.  Thanks in advance.
