Announcements
findEntityByToken on occ.component
m0d0
m0d0
Hi all,
I realised, that when trying to get a component with the findByentityToken it returns an occurrence object of this component instead of the component itself. This happens only when using occurrence.component.entityToken for generating the entityToken.
This is the code to reproduce:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        occ = ui.selectEntity('select Occurrence','Occurrences').entity
        comp = occ.component
        ui.messageBox(comp.classType())
        token = comp.entityToken
        entitiesByToken = des.findEntityByToken(token)
        ui.messageBox(str([entity.classType() for entity in entitiesByToken]))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
If you use design.allComponents to access the component and generating the token, design.findEntityByToken will return a component as exspected.
I know that I can simply use occ.component on the returned occurrence but I am still wondering about this behavior. Will this always work? Whats the reason for this distinction?
BrianEkins
This is a bug and needs to be fixed.  A bug has been logged.  Thanks for reporting it.
Brian Ekins
