Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
findBRepUsingRay returns unexpected result
2 REPLIES 2
karolis.s
91 Views, 2 Replies
I am currently working on an add-in for Autodesk Fusion 360, which involves reading and assigning names to faces on a currently active body. The primary objective is to determine the orientation of each face on the body, specifically identifying which faces are top, bottom, left, right, front, and back. This is achieved through a combination of methods, including finding minimum and maximum XYZ coordinates.
Here is a 3D model, including mitered angles, to illustrate the issue:
https://a360.co/3ZfcMxZ
The main challenge I am facing is related to the 'findBRepUsingRay' method, which, in some cases, returns more than zero intersections on mitered angle faces, despite there appearing to be no possible intersections from that particular point and direction. It's essential to note that all other bodies are hidden, and the ray is drawn from the centroid point of the face in question.
Below is a snippet of my code for reference:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # ui.messageBox('Hello script')
        cam: adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
        camOcc = cam.designRootOccurrence
        root_c = camOcc.component
        body :adsk.fusion.BRepBody = camOcc.bRepBodies[0]
        faces :adsk.fusion.BRepFaces = body.faces
        valid_faces = []
        intersection_faces = []
        for face in faces:
            intersections = root_c.findBRepUsingRay(
            face.centroid, get_normal(face), adsk.fusion.BRepEntityTypes.BRepFaceEntityType)
            if intersections.count == 0:
                valid_faces.append(face)
            else:
                intersection_faces.append(face)
        for item in valid_faces:
            draw_normal(item, 'None Intersections')
        for item in intersection_faces:
            draw_normal(item, 'Intersections')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_normal(face :adsk.fusion.BRepFace):
    evaluator = face.evaluator
    point_3d = adsk.core.Point3D.create(face.centroid.x, face.centroid.y, face.centroid.z)
    _, face_normal = evaluator.getNormalAtPoint(point_3d)
    return face_normal
def draw_normal(face :adsk.fusion.BRepFace,name):
    doc = Doc()
    normal = get_normal(face)
    centroid_point: adsk.core.Point3D = face.centroid.copy()
    normal.normalize()
    target_point: adsk.core.Point3D = centroid_point.copy()
    target_point.translateBy(normal)
    sketch: adsk.fusion.Sketch = doc.root_c.sketches.add(doc.root_c.xYConstructionPlane)
    sketch.name = name
    sketch.sketchCurves.sketchLines.addByTwoPoints(centroid_point, target_point)
import adsk, adsk.core, adsk.cam, adsk.fusion
class Doc:
    def __init__(self):
        productType = app.activeProduct.productType
        # root component
        self.root_c :adsk.fusion.Component = None
        self.body: adsk.fusion.BRepBody = None
        self.data_file = self.__get_active_doc_data_file()
        if productType == 'CAMProductType':
            self.root_c = camOcc.component
            camOcc.component
            self.body = camOcc.bRepBodies[0]
            self.cam: adsk.cam.CAM = cam
            # for setup in self.cam.setups:
            #     s :adsk.cam.Setup = setup
                # s.deleteMe()
        elif productType == 'DesignProductType':
            design = app.activeProduct
            self.root_c = design.rootComponent
            self.body = self.root_c.bRepBodies.item(0)
        if self.root_c == None or self.body == None:
            ui.messageBox('Active product is not Design or CAM product')
            return
    def __get_active_doc_data_file(self) -> adsk.core.DataFile:
        try:
            app: adsk.core.Application = adsk.core.Application.get()
            doc: adsk.core.Document = app.activeDocument
            return doc.dataFile
        except:
            return None
I would greatly appreciate any insights or suggestions from the community regarding this issue. Your expertise and guidance would be invaluable in refining this add-in to function seamlessly with complex 3D models.
Thank you in advance for your assistance.
Best regards, Karolis Šarskus
2 REPLIES 2
kandennti
in reply to: karolis.s
Hi @karolis.s .
It seems that the result returned by findBRepUsingRay sometimes includes the surface from which the center of gravity was obtained.
Therefore, I think you will get the desired result if you judge by the number of faces excluding the faces from which the center of gravity was obtained.
        for face in faces:
            intersections = [f for f in intersections if face.tempId != f.tempId] #here
            # intersections = [f for f in intersections if face.entityToken != f.entityToken]
            if len(intersections) < 1:
            else:
karolis.s
in reply to: kandennti
I think you are right about this method returning the same face, but for some reason I cannot make a check with entityToken and tempId, but I guess centroid comparison will do the job.
Thank you
