Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
findBRepUsingRay, multiple entity types
4 REPLIES 4
ebunn3
193 Views, 4 Replies
Is it possible to use the findBRepUsingRay with multiple entity types (face, edge, vertex).  I want to return information on all three but don't want to run the function 3 different times if I don't have to.
Eric
4 REPLIES 4
kandennti
in reply to: ebunn3
Hi @ebunn3 .
I'm not sure I understand your purpose. Why don't you create your own function to handle this?
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        hits = findBReps_UsingRay(
            root,
            adsk.core.Point3D.create(0,0,0),
            adsk.core.Vector3D.create(0,0,1),
        for idx, ent in enumerate(hits):
            print(f'{idx} - {ent.objectType}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def findBReps_UsingRay(
        comp: adsk.fusion.Component,
        originPoint: adsk.core.Point3D,
        rayDirection: adsk.core.Vector3D,
        proximityTolerance: float = -1.0,
        visibleEntitiesOnly: bool = True,
        hitPoints: adsk.core.ObjectCollection = None
    ) -> adsk.core.ObjectCollection:
    brepEntTypes = [
        adsk.fusion.BRepEntityTypes.BRepFaceEntityType,
        adsk.fusion.BRepEntityTypes.BRepEdgeEntityType,
        adsk.fusion.BRepEntityTypes.BRepVertexEntityType,
    ents: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
    pnts: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
    hits: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
    for entType in brepEntTypes:
        objs = comp.findBRepUsingRay(
            originPoint,
            rayDirection,
            entType,
            proximityTolerance,
            visibleEntitiesOnly,
            hits
        if objs.count < 1:
            continue
        for o, h in zip(objs, hits):
            ents.add(o)
            pnts.add(h)
    hitPoints = hits
    return ents
ebunn3
in reply to: kandennti
Thank you.  Let me take a look at your example and see if I can make that work.  I'm used to a similar function in Solidworks that will take an array of points, and return back the hit points and entities on anything it hits. Makes sense what you provided but I have to look at it a little harder.  Thanks.
Eric
BrianEkins
in reply to: ebunn3
One thing to consider, that's also mentioned in the documentation for findBRepUsingRay, is that if you hit a vertex you've also hit the edges that are connected by that vertex. It also means you've hit the faces that are connected by those edges.
Brian Ekins
ebunn3
in reply to: BrianEkins
Thanks Brian.
