Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
figure out file to edit based on current joint or rigidgroup.
2 REPLIES 2
kymC6Q8L
108 Views, 2 Replies
I have a project that has lots of nested linked files.
i need to fix a bunch of names or some of the joints and rigidgroups, and or provide a tool to alert people of what things need to be fixed.  Think of a tool for validating names for the processes we use.
Is there a method i can use from a body or occurance to tell me its current linked file or node in the browser that i need to edit?
Edit: fixed name of post.
Cheers
kym
2 REPLIES 2
kandennti
in reply to: kymC6Q8L
Hi @kymC6Q8L .
The UserInterface.commandStarting (or commandTerminated) event is fired each time a user operates the Fusion360.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-EBB6C82A-A256-4AB7-9A86-0F7A9653A7E9
Why not use this event to check for problems and alert the user?
kymC6Q8L
in reply to: kandennti
Hi @kandennti ,
this looks good, i will investigate this further.
cheers
Kym
