Feature Request? : API for creating and managing "Group"s in browser
nnikbin
Message 1 of 10
nnikbin
I was not able to find any API related to creation and management of "Group"s in browser (picture below). Is there such API available? I think having access to groups will be beneficial to the add-ins that create lots of bodies.
Replies (9)
Message 2 of 10
kandennti
Hi @nnikbin .
When I tried, I was able to create the group itself.
        # selections
        sels :adsk.core.Selections = ui.activeSelections
        sels.clear()
        # select root bodies
        bodies :adsk.fusion.BRepBodies = root.bRepBodies
        sels.add(bodies)
        # Create SurfaceGroup
        _app.executeTextCommand(u'Commands.Start FusionCreateSurfaceGroupCommand')
However, I looked for a way to access the group that was created, but could not find it.
I used this one as a reference.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/access-section-analysis/m-p/9700491#M11052
I also selected the group in the GUI and ran the text command here.
ObjectPaths.Show
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/master/TextCommands/TextCo...
The result is here.
ObjectPaths.Show
1 selections
Selection 0 has 4 elements
  ComponentBaseInstance (Unsaved) linkName: , (referenced component: FusionComponent - (Unsaved)), (CommonData CommonBaseEntData (base ManagedEntity (base Entity type ComponentInstanceMetaType id: 57 Subject count: 1 [EntityId: 3] ) : HasParent: 0) HasClientObject: 0)
  SurfaceGroups (base CommonBaseEntData (base ManagedGroupEntity (base ManagedEntity (base Entity type SurfaceGroupsMetaType id: 21 ) : HasParent: 1) children : 1) HasClientObject: 0)
  ManagedGroupEntity (base ManagedEntity (base Entity type SurfaceGroupMetaType id: 256 ) : HasParent: 1) children : 0
I have a feeling it has something to do with SurfaceGroups, but I don't know how to get here.
We also know that the command ID for the "MOVE TO GROUP" command is "FUSIONMoveToSurfaceGroupCommand".
Message 3 of 10
nnikbin
Hi @kandennti ,
Awesome!, Thank you for your reply. Is it possible to rename the created group? (I know that you mentioned you were not able to find a solution for getting access to created group). I need creating groups with some dynamic names.
And a general question: Is it possible to pass arguments to commands using executeTextCommand or all of the commands only use the current context?
Message 4 of 10
kandennti
We have made some progress.
The group could be renamed to any name.
        # selections
        sels.clear()
        sels.add(bodies)
        # get SurfaceGroups Properties
        # SurfaceGroups(SurfaceGroupsMetaType id: 21)
        surfaceGroupsProp = _app.executeTextCommand(u'PEntity.Properties 21')
        # Convert to json
        import json
        surfaceGroups = json.loads(surfaceGroupsProp)
        # SurfaceGroup count
        surfaceGroups_count = len(surfaceGroups['children'])
        print(str(surfaceGroups_count))
        # get Target Id
        targetId = surfaceGroups['children'][surfaceGroups_count - 1]['entityId']
        # Rename SurfaceGroup
        newGroupName = 'hoge'
        _app.executeTextCommand(u'PInterfaces.Rename {} {}'.format(targetId, newGroupName))
Thanks to @thomasa88 !
Message 5 of 10
nnikbin
Wonderful workaround! Tanks a lot @kandennti and @thomasa88 !
Message 6 of 10
kandennti
Limited, but seems to have reached the goal.
(The root component is only)
The following sample creates 10 bodies and divides them into two groups.
# Fusion360API Python script-sample_CreateBodyGroup
# Fusion360 ver2.0.9313
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
import json
def createBoxesGroup(
    groupName :str,
    bodiesList :list
    app = adsk.core.Application.get()
    ui = app.userInterface
    des  :adsk.fusion.Design = _app.activeProduct
    root :adsk.fusion.Component = des.rootComponent
    # selections
    sels.clear()
    sels.add(bodies)
    surfaceGroupsProp = app.executeTextCommand(u'PEntity.Properties 21')
    # Convert to json
    # print(str(surfaceGroups_count))
    # get Target Id
    app.executeTextCommand(u'PInterfaces.Rename {} {}'.format(targetId, groupName))
    # select bodiesList
    [sels.add(body) for body in bodiesList]
    # select SurfaceGroup
    # https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/master/TextCommands/TextCommands_txt_Ver2_0_8176.txt#L2058
    # Except for the root component, the <Paths> need to be changed.
    app.executeTextCommand(u'Selections.Add 57:3:21:{}'.format(targetId))
    # exec FusionMoveToSurfaceGroupCommand
    app.executeTextCommand(u'Commands.Start FusionMoveToSurfaceGroupCommand')
    app.executeTextCommand(u'NuCommands.CommitCmd')
def createBoxes(
    comp :adsk.fusion.Component,
    count :int
    def createBox(
        pnt :adsk.core.Point3D
        ) -> adsk.fusion.BRepBody:
        vec3D = adsk.core.Vector3D
        lVec = vec3D.create(1.0, 0.0, 0.0)
        wVec= vec3D.create(0.0, 1.0, 0.0)
        bouBox3D = adsk.core.OrientedBoundingBox3D
        box = bouBox3D.create(pnt, lVec, wVec, 10, 10, 10)
        tmpBrMgr = adsk.fusion.TemporaryBRepManager.get()
        baseFeats = comp.features.baseFeatures
        baseFeat = baseFeats.add()
        baseFeat.startEdit()
        cube :adsk.fusion.BRepBody = comp.bRepBodies.add(tmpBrMgr.createBox(box),baseFeat)
        baseFeat.finishEdit()
        return cube
    # return boxis
    for idx in range(count):
        createBox(
            comp,
            adsk.core.Point3D.create(0.0 + float(20.0 * idx), 0.0, 0.0))
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        _app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        # createBoxes
        createBoxes(root, 10)
        # message
        vp :adsk.core.Viewport = _app.activeViewport
        vp.fit()
        _ui.messageBox('Group the bodies.')
        # Grouping
        groupOdd = [box for idx,box in enumerate(root.bRepBodies) if idx % 2 == 0]
        groupEven = [box for idx,box in enumerate(root.bRepBodies) if idx % 2 != 0]
        # createBoxesGroup
        createBoxesGroup('Odd', groupOdd)
        createBoxesGroup('Even', groupEven)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Although limited to the root component, I think it will work if you copy the createBoxesGroup function and call it with a group name and a list of bodies as parameters.
I could learn a lot from it. Thank you.
Message 7 of 10
nnikbin
Great! Thank you @kandennti
Message 8 of 10
nnikbin
I hope Autodesk publishes APIs for Groups and Selection Sets. Meanwhile we can use @kandennti 's nice solution at least for our internal apps.
Message 9 of 10
kandennti
I followed the example of the president of some country and never gave up, and as a result, I was able to create a group within the component (Occurrence) as well.
It got too long, so I decided to publish it on github.
https://github.com/kantoku-code/sample_CreateBodyGroup
Message 10 of 10
nnikbin
Perfect! Thank you @kandennti !
