Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Failed upload on large files
1 REPLY 1
reedwindmillerBA43M
168 Views, 1 Reply
Hi, I'm having trouble uploading a large file (908,085 kb to be exact) and have tried to upload from my backup drive or main drive with no luck.  Every time it gets about half way through and freezes up the status bar.  Some time later I get a message saying it failed to upload.  Is this file just to large to upload?  Its an .x_t file so I can't directly open it up either.
1 REPLY 1
This forum is specifically for Fusion 360 programming interface questions and it's not likely that someone that can answer your question will see it here.  I suggest that you re-post your question on the A360 forum since that's what is actually responsible for the upload.
https://forums.autodesk.com/t5/a360-forum/bd-p/205
Brian Ekins
Mod the Machine blog
