F360 API Defects in textBoxCommandInput
william-c-anderson
william-c-anderson
An editable textBoxCommandInput (or simply, "textBox") has the following defects when dealing with HTML pre-formatted text (e.g. text that uses the <pre> tag):
  1. If the formatted text is loaded via the textBox_var.formattedText property and is unedited by the user and then retrieved via the textBox_var.text property, formatting is retrieved along with the text.
  2. In formatted text, the HTML parameter 'tab-size' is ignored. The tab size is a constant inch or so, which is very large for the scale of a typical screen. This is also true, evidently, for the parameter 'font-size'.
  3. In the case of HTML pre-formatted text (e.g. the <pre> tag), if text is inserted by the user in the middle of existing text, line spacing is normal. However, if the user appends text to the end of the existing text, the line spacing is shown to be double. Retrieved (unformatted) text is as expected.
  4. If pre-formatted text is copied from an HTML file (e.g. a "Help" file) and then pasted into a textBox, the HTML formatting that has come along with the paste evidently causes some garbled formatting to be retrieved along with the text, similar to item 1).
  5. In all cases, a textBox with numRows > 4 fails to render the bottom (blue) border.
Lest you think that these are unimportant appearance-only issues for the API, let me assure you that items 1) and 4) will definitely break code. Also, if you are trying to get a user to input a lengthy parameter list, the formatting does make a very significant impact to readability, which is critical for F360 commands.
Here is a script (adapted from the API sampler) wherein a user can demonstrate these defects. Note that a pre-formatted string 'initText' is a global which can be easily modified to test other HTML parameters:
#Author-WCA
#Description-Simple script to test formatted text.
#Adapted from ADSK API Sampler
import adsk.core, adsk.fusion, traceback
cmdId = "YAtextBoxTest"
#initText = "Unformatted text added by formattedText propterty"
initText = '''<html>
<head>
<style>
pre {
    white-space:pre-wrap;
    tab-size: 2;
    display: block;
    line-height: 100%;
	font-family: Courier;
</style>
</head>
<body>
<pre>
Pre-formatted text
	one tab
		two tabs
			three tabs
How does the line spacing look?
</pre>
</body>
</html>'''
_app = None
_ui  = None
_rowNumber = 0
_textbox = None
# Global set of event handlers to keep them referenced for the duration of the command
_handlers = []
# Input Changed Event Handler
class MyCommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            inputs = eventArgs.inputs
            cmdInput = eventArgs.input
            pass
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Destruction Event Handler
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            _ui.messageBox('textBox.text:\n{}'.format(_textbox.text))
            adsk.terminate()
        except:
# Creation Event Handler (called from run())
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            global _textbox
            # Get the command that was created.
            cmd = adsk.core.Command.cast(args.command)
            # Connect to the command destroyed event.
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            # Connect to the input changed event.
            onInputChanged = MyCommandInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            # Get the CommandInputs collection associated with the command.
            inputs = cmd.commandInputs
            # Create an editable textbox input.
            textBox = inputs.addTextBoxCommandInput('writable_textBox', '', '', 10, False)
            textBox.formattedText = initText
            #textBox.text = initText
            textBox.isFullWidth = True
            _textbox = textBox
        except:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        # Get the existing command definition or create it if it doesn't already exist.
        cmdDef = _ui.commandDefinitions.itemById(cmdId)
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(cmdId, 'TextBox Test', 'TextBox Test')
        # Connect to the command created event.
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        # Execute the command definition.
        cmdDef.execute()
        # Prevent this module from being terminated when the script returns, because we are waiting for event handlers to fire.
        adsk.autoTerminate(False)
    except:
        if _ui:
william-c-anderson
I'm really sorry - I thought I posted this to the Support forum. Is there some way to move it?
william-c-anderson
(This was originally posted to the F360 API forum, but it is a bug report, so I'm reposting it here - sorry - I couldn't find a way to move the post from there to here...)
#Author-WCA
<head>
<style>
pre {
    tab-size: 2;
    display: block;
    line-height: 100%;
</style>
</head>
<body>
<pre>
Pre-formatted text
	one tab
		two tabs
			three tabs
</pre>
</body>
</html>'''
_app = None
_ui  = None
_rowNumber = 0
_textbox = None
_handlers = []
    def __init__(self):
        super().__init__()
        try:
            pass
        except:
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
    def __init__(self):
        super().__init__()
        try:
            global _textbox
            _textbox = textBox
        except:
def run(context):
    try:
        global _app, _ui
        if not cmdDef:
        cmdDef.execute()
    except:
        if _ui:
william-c-anderson
Reposted to Support forum as a bug report - sorry to clutter up this forum.
