Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Extrude Surfaces same plane (not on the same plane error)
4 REPLIES 4
sebmorales
538 Views, 4 Replies
Hola!
I am having some problems with a script that will slice a part with a plane, then project the intersection of the part with the plane on a sketch. Finally, it will extrude those profiles (as surfaces).
The script works fine for most geometries but occasionally crashes giving the error: "input curves are not on the same plane". I don't understand how this is happening since the input curves were created by the plane to begin with.
Any ideas? Is this a bug?
I am attaching a sample file where this problem occurs as well as the script where this occurs (it is attached as txt because it wouldn't let me upload a .py file).
Thanks!
Sebastian
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
app = adsk.core.Application.get()
if app:
    ui = app.userInterface
def run(context):
    try:
        activeDoc = adsk.core.Application.get().activeDocument
        design = activeDoc.design
        rootComp = design.rootComponent
        rootComp.occurrences.addNewComponent (adsk.core.Matrix3D.create()).component.name=("extrusions")
        modelMinZ=rootComp.boundingBox.minPoint.z+0.002
        planes=rootComp.constructionPlanes
        planeInOff=planes.createInput()
        planeInOff.setByOffset(rootComp.xYConstructionPlane,adsk.core.ValueInput.createByReal(modelMinZ))
        planeMin=planes.add(planeInOff)
        planeMin.isLightBulbOn=False
        sketches= rootComp.sketches
        sketch = sketches.add(planeMin)
        body = rootComp.bRepBodies.item(0)
        sketch.projectCutEdges(body)
        extrudesComp = rootComp.occurrences.itemByName("extrusions:1").component
        extrudes = extrudesComp.features.extrudeFeatures
        distance = adsk.core.ValueInput.createByReal(2)
        curves=sketch.sketchCurves.item(0)
        profileCollection = adsk.core.ObjectCollection.create()
        profileCollection.add(rootComp.createOpenProfile(curves))
        extrudeInput = extrudes.createInput(profileCollection, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        extrudeInput.isSolid = False
        extrudeInput.setDistanceExtent(False, distance)
        extrude = extrudes.add(extrudeInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Error Message
4 REPLIES 4
ekinsb
in reply to: sebmorales
There does appear to be a problem in the API that I'll log a bug for.
However, there's another approach that is better and works.  If you remove the crossed out lines below and add the code in red, it works.
        prof = sketch.profiles.item(0)
        extrudeInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
Brian Ekins
Mod the Machine blog
sebmorales
in reply to: ekinsb
Awesome! This works pretty well. Do you know how this could work in case the profile was open? Lets say the input body is not solid but a surface?
Thanks!
ekinsb
I'm not finding a way that works with an open profile.  We're in the process of changing the concept of a Profile so that Profiles should only be used for closed 2D sections.  Paths should be used for open and/or 3D sets of connected curves.  With this new concept, you should be creating a Path instead of a Profile, but I tested that too and it also has a problem.  I've logged both of the issues so we can get them fixed.  The only thing I found that worked is if I just extrude one curve at a time.
Brian Ekins
sebmorales
in reply to: ekinsb
That sounds ideal, and thoughts for when this might be released? I just want to know if I should try to fix it now another way or if I should just wait.
Thank you for taking a dive at it though!
Sebastian
