Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Extrude Objects to Cut
3 REPLIES 3
commonmandan
694 Views, 3 Replies
I've made an add-in which creates a new component which has 2 sketches and a body from an extrusion of the first sketch. I'd like to cut into the body with a profile from the second sketch without cutting into any other bodies that may or may not exist and may or may not be visible. I've looked through the API documentation for something similar to the "objects to cut" without any success.
cuts = newComp.features.extrudeFeatures
extInput = cuts.createInput(frontSketch.profiles.item(0), adsk.fusion.FeatureOperations.CutFeatureOperation)
extent_all_ne = adsk.fusion.ThroughAllExtentDefinition.create(False)
extInput.setOneSideExtent(extent_all_ne, adsk.fusion.ExtentDirections.NegativeExtentDirection)
ext2 = cuts.add(extInput)
The code above cuts through everything.
3 REPLIES 3
MaxJeblick
in reply to: commonmandan
I faced the same issue. One workaround for this problem is to turn the visibility of all bodies but the ones you want to cut off. This is the same procedure you did in Fusion to exclude certain bodies from being cut prior they modified the extrude command. This workaround seems not to be optimal, but I'm not aware of an method equivalent to the objects-to-cut functionality within the API.
ekinsb
in reply to: MaxJeblick
What's been said is correct; to control which bodies participate in the extrusion you need to set their visibility.  The new capability to select which bodies participate is coming to the API in the next major update in January.
Brian Ekins
Mod the Machine blog
MaxJeblick
in reply to: ekinsb
That sounds great! Looking forward for the new features.
