Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Extract point coordinates
3 REPLIES 3
Ex_Machina_Engineering
1468 Views, 3 Replies
In there a tool or add-in that I use to extract coordinates of points on a line, arc, spline, etc.?
3 REPLIES 3
may be you can write a script with following code. This will display coordinate of sketch point in a message box.
app = ask.core.Application.get()
ui = app.userInterface
pntEntity = ui.selectEntity('Select a sketch point', 'SketchPoints')
pnt = adsk.fusion.SketchPoint.cast(pntEntity.entity)
ui.messageBox('x:{0},y:{1},z:{2}'.format(pnt.geometry.x,pnt.geometry.y,pnt.geometry.z))
Shyam Goyal
Sr. Software Dev. Manager
therealsamchaney
in reply to: goyals
Thanks! Would you mind elaborating a bit about this code? Specifically, what is the .cast method? I don't see it listed in the page about the SketchPoint object. Also, what is the .entity method you call on the point entity?
At first I was lost as to how to use the geometry attribute but then I found that it's a Point3D type object and this page was very helpful for me. Hope someone else finds this useful.
Read the "Code Hints" section there: Python Specific Issues
Read the UserInterface.selectEntity method documentation and the Selection Object documentation.
