Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Extension InViewerSearch
1 REPLY 1
claraarias
428 Views, 1 Reply
               We want to add our viewer extension: Autodesk.InViewerSearch
I have done the steps indicated in the link:
https://developer.autodesk.com/en/docs/viewer/v2/tutorials/in-viewer-search-ext/
The declaration of the variable config3d:
var config3d = {
    extensions: ['MyBotonesExtension', 'Autodesk.InViewerSearch']
config3d.inViewerSearchConfig = {
            searchDefaultText: "",
            uiEnabled: true,
            clientId: 'adsk.viewer.defaultClientId',
            sessionId: 'adsk.viewer.defaultSessionId',
        relatedItemsTab:{
            enabled: true,  //if false we hide the tab
            displayName: 'This Item',
            pageSize: 20
        loadedModelTab: {
            displayName: 'This View',
            pageSize: 50
viewerApp.registerViewer(viewerApp.k3D, Autodesk.Viewing.Private.GuiViewer3D, config3d);
In my index.html:
    <script src="https://developer.api.autodesk.com/viewingservice/v1/viewers/three.min.js"></script>
    <script src="scripts/Extension-InViewerSearch.js"></script>
    <script src="https://developer.api.autodesk.com/viewingservice/v1/viewers/viewer3D.min.js?v=2.11.*"></script>
Extension-InViewerSearch.js->
https://autodeskviewer.com/viewers-dev/latest/docs/extensions_InviewerSearch_InViewerSearchExtension...
ERROR:
ypeError: n[m] is undefined
i.initSharedPropertyDatabase()    viewer3D.min.js:38
i.initCurrentPropertyDatabase()   viewer3D.min.js:38
i.getCurrentGeometryAttributes()  viewer3D.min.js:38
f/h.initializeAllAttributes()     viewer3D.min.js:38
j.InViewerSearchThisView.prototype.initialize()  viewer3D.min.js:38
a() viewer3D.min.js:36
h/p() viewer3D.min.js:36
f/<()
I change viewer3d.min.js by viewer3d.js
ERROR IN viewer3D.js:
ypeError: geometriesFlat[current] is undefined
proto.initSharedPropertyDatabase() viewer3D.js:89706
proto.initCurrentPropertyDatabase() viewer3D.js:89724
proto.getCurrentGeometryAttributes() viewer3D.js:89778
Controller/ctrl.initializeAllAttributes() viewer3D.js:88945
viewerSearchNameSpace.InViewerSearchThisView.prototype.initialize() viewer3D.js:88260
initializeSearchTabs() viewer3D.js:85412
initialize/onGetGeometriesDone() viewer3D.js:85603
getGeometries/<()
I made another extension running development differently, when the geometry is loaded and ... the result has been the same ... same error:
viewer.addEventListener(Autodesk.Viewing.GEOMETRY_LOADED_EVENT,
                    function (event) {
                        var options = {
                            uiEnabled: true,
                            thresholdSearchMaxNodes: 50000,
                            loadedModelTab: {
                                enabled: true,
                                pageSize: 50
                            relatedItemsTab: {
                                enabled: true,
                                pageSize: 20
                        viewer.loadExtension("Autodesk.InViewerSearch", options);……..
 In the display only shows the magnifying glass icon.
I hope to hear from somebody soon...
<br class="Apple-interchange-newline"><div id="inner-editor"></div>
Thank you so much
1 REPLY 1
ekinsb
in reply to: claraarias
This forum is for questions about Fusion 360. For Forge questions they're using Stackoverflow and the Forge experts are watching there for questions.  Can you please re-post your question on Stackoverflow?
Brian Ekins
Mod the Machine blog
