Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
ExportManager(stlOptions) RuntimeError: 2 : InternalValidationError : success
3 REPLIES 3
Le_Bear
203 Views, 3 Replies
Ok I must say, I love it ! 😍
I get an error to tell me "success" 🤣
Anyway, this is pretty annoying , as the script stop working, after running properly for a while.
Here is the exact error I am getting (sorry, repetitive errors trying to upload that tiny image)
here is the script itself, s it's pretty short:
#Author-BG
#Description-Copy bodies from a full assembly into a single component, to make it easier to export a STL
# The goal is to copy bodies from a full assembly into a new component, so that it will be possible
# to export as STL from Fusion with a common origin (and axis)
# Beginning on 23/2/2020 :59 by BG
# Now the script DO NOT copy bodies, just export them as STL, only if the component is visible
import adsk.core, adsk.fusion, traceback
# Create a collection to store our bodies
sourceBodies = adsk.core.ObjectCollection.create()
folder = "C:/Users/bgros/Documents/Rosetta/Machine Nicolas/ApiExport"
def traverse(occurences):
    # recursive method to get all bodies from components and sub-components
    for occ in occurences:
        visiFlag = occ.isLightBulbOn
        bodies = occ.bRepBodies
        for bod in bodies:
            if visiFlag:
                bod.name = occ.fullPathName
                sourceBodies.add(bod)
                adsk.doEvents()
                visiFlag = False
        if occ.childOccurrences:
            traverse(occ.childOccurrences)
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get active design
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('It is not supported in current workspace, please change to MODEL workspace and try again.')
            return
        # History must be captured for this to work
        if design.designType == adsk.fusion.DesignTypes.DirectDesignType:
            design.designType = adsk.fusion.DesignTypes.ParametricDesignType
        # Get root component in this design
        rootComp = design.rootComponent
        # Get all Components below root
        occs = rootComp.occurrences
        # add all bodies from all components in the collection
        traverse(occs)
        # # create the new component , adding "for STL Export" to the name
        # newComp = occs.addNewComponent(adsk.core.Matrix3D.create())
        # newComp.component.name = rootComp.name + " for STL Export"
        adsk.doEvents()
        # copy paste ALL bodies to the new component
        #newComp.component.features.copyPasteBodies.add(sourceBodies)
        for oneBody in sourceBodies:
            #oneBody.name = rootComp.name + " " + oneBody.name
            # newComp.component.features.copyPasteBodies.add(oneBody)
            # Construct the output filename.
            oneBody.name = oneBody.name.replace(":", "-")
            filename = folder + "/" + oneBody.name + '.stl'
            # Save the file as STL.
            exportMgr = adsk.fusion.ExportManager.cast(design.exportManager)
            stlOptions = exportMgr.createSTLExportOptions(oneBody, filename)
            stlOptions.meshRefinement = adsk.fusion.MeshRefinementSettings.MeshRefinementHigh
            stlOptions.isOneFilePerBody = True
            stlOptions.sendToPrintUtility = False
            exportMgr.execute(stlOptions)
            adsk.doEvents()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
3 REPLIES 3
Le_Bear
in reply to: Le_Bear
It looks like it may be linked to the full pathname being too long. I would like if someone in the known could confirm, and also if it would be possible to have an helping exception, rather than the quite cryptic "success".
Bernard Grosperrin
BrianEkins
This is a known issue that True is returned even when the translation has failed.  Hopefully, it will be addressed soon.
Brian Ekins
Le_Bear
in reply to: BrianEkins
Translation ? Into an STL, you mean? OK, good to know it is known, not just some mistake from me. Is there any workaround possible ? At least to know what could make it fail.
Thanks for your help.
Bernard Grosperrin
