Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Exporting Cut List to Otto Mayer
1 REPLY 1
brandonHWC2G
412 Views, 1 Reply
Hi, we have Autodesk 2018 but we use an Ardis Easy Optimizer to optimize the parts and export the file as either .may or .asc to input into the panel saw. It is an Otto Mayer PS9Z, if that matters. It uses an old terminal that has an Otto Mayer program hardprogrammed in. Can Fusion360 export a cut list into .may or .asc?
Thank you.
1 REPLY 1
BrianEkins
in reply to: brandonHWC2G
Fusion doesn't have built-in capabilities to export a file to control an Otto Mayer panel saw.  It might be possible to write an exporter, but I did a quick search and couldn't find out any information about the format they use.  I suspect it may not be a public format since they provide a software application for defining the cuts and the cutting plan.
Brian Ekins
