Export surface from plane cut
ivr22
ivr22
Hi all,
I'm new to the Fusion 360 API and am looking for a way to automate the exporting of the surface (or just the points along the edge of the surface) when doing a plane cut along a body.
I've managed to make a plane cut along a spiral path along a defined spline and am automating that. But then I need to export the export the intersection of the plane and the body to get the cross-sectional area etc. (shown in blue in the second image. I need to do this in Python to automate the extraction of the surface along 100 points along that spiral.
I've included images below to help demonstrate what's needed. Any pointers will be greatly appreciated.
Thanks!
Iwan
kandennti
Hi @ivr22 .
It looked like fun, so I gave it a try.
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        # select body
        msg :str = 'Select Body'
        selFiltter :str = 'Bodies'
        sel :adsk.core.Selection = selectEnt(msg ,selFiltter)
        if not sel: return
        body :adsk.fusion.BRepBody = sel.entity
        # select guide curve
        msg = 'Select Guide Curve (SketchCurves)'
        selFiltter = 'SketchCurves'
        if not sel: return
        crv :adsk.fusion.SketchCurve = sel.entity
        # create Cross Section Surfaces
        createCrossSections(body, crv, 100)
        # finish
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def createCrossSections(
    body :adsk.fusion.BRepBody,
    sktCrv :adsk.fusion.SketchCurve,
    count :int) -> list:
    # -- support function --
    def getParams(
        crv :adsk.core.Curve3D) -> list:
        # get Evaluator
        eva :adsk.core.CurveEvaluator3D = crv.evaluator
        # get start end point
        _, startPnt, endPnt = eva.getEndPoints()
        # get start/end parameter
        _, sPrm = eva.getParameterAtPoint(startPnt)
        _, ePrm = eva.getParameterAtPoint(endPnt)
        # get length
        _, length = eva.getLengthAtParameter(sPrm, ePrm)
        # get step
        step = length / (count + 1)
        # get parameter
        prms = []
        for idx in range(1,count+1):
            _, prm = eva.getParameterAtLength(sPrm, step * idx)
            prms.append(prm)
        return prms
    def getPlanes(
        crv :adsk.core.Curve3D,
        parameters :list) -> list:
        # get Evaluator
        # get tangent
        _, tangents = eva.getTangents(parameters)
        tans = [t for t in tangents]
        # point3d
        _, points = eva.getPointsAtParameters(parameters)
        pnts = [p for p in points]
        # plane
        Plane = adsk.core.Plane
        return  [Plane.create(p, v) for p, v in zip(pnts, tans)]
    def initCrossSections(
        planes :list) -> list:
        tmpMgr :adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
        surfs = []
        for pln in planes:
            wire = tmpMgr.planeIntersection(body, pln)
            if not wire:
                continue
            surf = tmpMgr.createFaceFromPlanarWires([wire])
            if not surf:
                continue
            surfs.append(surf)
        return surfs
    def addSurfs(
        comp :adsk.fusion.Component,
        surfs :list) -> list:
        bodies = comp.bRepBodies
        des :adsk.fusion.Design = comp.parentDesign
        breps =[]
        if des.designType == adsk.fusion.DesignTypes.DirectDesignType:
            breps = [bodies.add(surf) for surf in surfs]
        else:
            baseFeatures = comp.features.baseFeatures
            baseFeature = baseFeatures.add()
            baseFeature.startEdit()
            for surf in surfs:
                try:
                    breps.append(bodies.add(surf, baseFeature))
                except:
                    pass
            baseFeature.finishEdit()
        return breps
    # Curve
    crv = sktCrv.worldGeometry
    # Params
    prms = getParams(crv)
    # Planes
    plns = getPlanes(crv, prms)
    # CrossSections
    surfs = initCrossSections(body, plns)
    # add surfaces
    comp = sktCrv.parentSketch.parentComponent
    breps = addSurfs(comp, surfs)
    return breps
def selectEnt(
        msg :str,
        filtterStr :str) -> adsk.core.Selection :
    try:
        app = adsk.core.Application.get()
        sel = ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
However, I don't think you can get the same results with anything other than the root component.
Also, if you have a cut that has multiple cross sections, you will have multiple surfaces.
ivr22
That's amazing. Thank you so much.
To characterise the slices, I'm looking to export them to Python or Matlab to either get the edge of the slices as splines or surfaces. I can then filter to the surface of interest (of the multiple cuts) characterise them. Any idea on how to do this?
I'm also sometimes getting this error message when trying to run the code. Any idea of why this error would appear?
Thank you so much. This is extremely helpful for my research.
kandennti
I'm sorry, but I don't understand English at all, so I didn't understand your question about the filter.
As for the part where the error is occurring, that part uses the method here.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-18D6210D-FF0A-4CA8-8244-CFDC30213A4D
In the documentation, it says something like this.
"Each wire must be closed, they should not overlap, and they should all lie on the same plane."
I think the boundary to create the surface is probably overlapping, but I can't find the correct cause without trying with actual data.
ivr22
Thank you. Can we replace the createFacefromPlanarWires with the create plane along edge function (https://help.autodesk.com/view/fusion360/ENU/?guid=SLD-CONSTRUCT-PLANE-ALONG-PATH) or is that not included in the API?
Also my question about faces was about exporting the faces you made as splines (or something similar) for further analysis in Python or Matlab. Do you know if that's possible?
Thanks!
kandennti
@ivr22 .
It is possible to create a "plane along path". However, you will need to modify it drastically.
I've never used Matlab before, is it possible to import Iges/Step files?
kandennti
@ivr22 .
Fixed.
def run(context):
    try:
        # Parametric mode only
        des :adsk.fusion.Design = app.activeProduct
        if des.designType != adsk.fusion.DesignTypes.ParametricDesignType:
            ui.messageBox('Parametric mode only')
            return
        # select body
        if not sel: return
        if not sel: return
        # finish
    except:
        if ui:
    def getRatios(
        step = 1 / count
        ratios = [v * step for v in range(count)]
        ratios.append(1)
        return ratios
    def getPlanes(
        sktCrv :adsk.fusion.SketchCurve ,
        ratios :list) -> list:
        comp :adsk.fusion.Component = sktCrv.parentSketch.parentComponent
        conPlanes :adsk.fusion.ConstructionPlanes = comp.constructionPlanes
        plnIpt :adsk.fusion.ConstructionPlaneInput = conPlanes.createInput()
        valIpt :adsk.core.ValueInput
        plns = []
        for ratio in ratios:
            valIpt = adsk.core.ValueInput.createByReal(ratio)
            plnIpt.setByDistanceOnPath(sktCrv, valIpt)
            plns.append(conPlanes.add(plnIpt))
            adsk.doEvents()
        return plns
    def initSketch(
        plane :adsk.fusion.ConstructionPlane) -> adsk.fusion.Sketch:
        skts :adsk.fusion.Sketches = plane.component.sketches
        return skts.add(plane)
        planes :list):
        skts = []
        for plane in planes:
            skt :adsk.fusion.Sketch = initSketch(plane)
            skt.projectCutEdges(body)
            if skt.profiles.count > 0:
                skts.append(skt)
            else:
                skt.deleteMe()
            adsk.doEvents()
        return skts
    def initSurfs(
        skts :list) -> list:
        comp :adsk.fusion.Component = skts[0].parentComponent
        PatchFeats :adsk.fusion.PatchFeatures = comp.features.patchFeatures
        NEWBODY = adsk.fusion.FeatureOperations.NewBodyFeatureOperation
        surfs = []
        for skt in skts:
            if skt.profiles.count < 1:
                continue
            for pro in skt.profiles:
                PatchIpt :adsk.fusion.PatchFeatureInput = PatchFeats.createInput(pro, NEWBODY)
                PatchFeat :adsk.fusion.PatchFeature = PatchFeats.add(PatchIpt)
                surfs.extend([f for f in PatchFeat.faces])
            adsk.doEvents()
        return surfs
    # ratio
    ratios = getRatios(count)
    # Planes
    plns = getPlanes(sktCrv, ratios)
    # CrossSections
    skts = initCrossSections(body, plns)
    if len(skts) < 1:
        return []
    # add surfaces
    surfs = initSurfs(skts)
    return surfs
def selectEnt(
        msg :str,
    try:
        return sel
    except:
        return None
・It works only in parametric mode, because it cannot create the correct plane in direct mode.
・Processing is very slow compared to the first one.
Nothing has been done about exporting.
