Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Example script Add-In fails in validateInputs handler
1 REPLY 1
wh6Q9NU
105 Views, 1 Reply
When creating a new (default) Add-In, from:
  1. "Script and Add-Ins" (Shift + S)
  2. Tab "Add-Ins"
  3. Click "Create" and select type Python
  4. Open the freshly generate Add-In example and open the file: "entry.py"
  5. Around line 138 with the command definition "def command_validate_input" we see at line 147 "
    inputs.areInputsValid = True"
This is failing. The fix I applied is: "args.areInputsValid = True", then the "OK" button is correctly disabled with an input value below 0.
Please check and correct. Thanks!
1 REPLY 1
Rushikesh.kadam
in reply to: wh6Q9NU
@wh6Q9NU Thank you for reporting it. I have created a ticket and assigned it to the concerned team.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
