Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Event when CommandInput is focused?
2 REPLIES 2
thomasa88
191 Views, 2 Replies
Is there any way to get an event when a (StringValue)CommandInput gets focus?
My code highlights the object the user is currently editing info about, but the way I do it right now is using "Command.inputChanged", which makes the selection not update until the user edits the text.
2 REPLIES 2
BrianEkins
in reply to: thomasa88
No, there isn't an event when an input gets focus.  It's a good idea but it doesn't currently exist.
Brian Ekins
thomasa88
in reply to: BrianEkins
I understand.
Interesting observation, for anyone else trying to do the same:
command.inputChanged is triggered whenever someone focuses a CommandInput inside a TableCommandInput using the mouse. inputChanged is not triggered if Tab key is used.
It also has the bonus of saying which input was focused ("changed").
