Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Error in simply script to post all operations as separate file
4 REPLIES 4
maurizio_manzi
132 Views, 4 Replies
I want to post any operation in a separate file.
The script is very easy, but I get an error message after a few operations.
I can't found any error in the script itself.
Attached fusion360 cam-part and the script.
Path and name of the pp must be selected in the script. Also the nc-output folder.
Best regards
Maurizio
4 REPLIES 4
kandennti
in reply to: maurizio_manzi
Hi @maurizio_manzi .
There was no cps file, so I tried "fanuc.cps".
I tried that and it gave me an error if the name of the NC program is not a number.
I could avoid the error by doing this, but the file name is not what I want.
        setups = cam.setups
        setup = setups.item(0)
        nameNum = 100
        for setup in setups:
            folders = setup.folders
            for folder in folders:
                operations = folder.allOperations
                for operation in operations:
                    if operation.hasToolpath == True:
                        # postInput = adsk.cam.PostProcessInput.create(operation.name, postConfig, outputFolder, units)
                        postInput = adsk.cam.PostProcessInput.create(str(nameNum), postConfig, outputFolder, units)
                        postInput.isOpenInEditor = viewResult
                        cam.postProcess(operation, postInput)
                        nameNum += 1
I could not figure out if there is a corresponding field in the "File name" of the GUI.
maurizio_manzi
in reply to: kandennti
you can post with the Heidenhain PP (now attached).
My problem is not the file name.
I think, it's a software bug in Fusion.
It works until the operation not have any tool-orientation.
At the first operation with a tool-orientation, you get an internal error.
Best regards
Maurizio
kandennti
@maurizio_manzi .
We found the cause.
It was simply because the file name contained characters that could not be used.
        setups = cam.setups
        import re
                        file_name = re.sub(r'[\\|/|:|?|.|"|<|>|\|]', '_', operation.name)
                        postInput = adsk.cam.PostProcessInput.create(file_name, postConfig, outputFolder, units)
maurizio_manzi
Thank you very much
