Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Error in Python code
4 REPLIES 4
Peter__B
1129 Views, 4 Replies
Hi
The following python code is just for trying to learn the python script code for The Fusion 360 and does not produce any valuable output. However, does anybody know why the following code does not work and generates the error message below ?
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
text='string'
print(1,'=',text)
def run(context):
    ui = None
    try:
       global text
       app = adsk.core.Application.get()
       ui  = app.userInterface
#       ui.messageBox('Hello script')
       newProj = app.data.dataProjects.add('myNewProj')
       newFold = newProj.rootFolder.dataFolders.add('myNewFold')
       newDoc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
#       product = app.activeProduct
#       design = adsk.fusion.Design.cast(product)
       rootComp = design.rootComponent
       occ = rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
       occ.activate()
       newComp = occ.component
       newComp.name = 'Beam'
       sketches = newComp.sketches
       text='newstring'
#       print(2,'=',text)
       xyPlane = newComp.xYConstructionPlane
       sketch = sketches.add(xyPlane)
       sketch.name = 'FirstSketch'
#       xzPlane = rootComp.xZConstructionPlane
#       sketch = sketches.add(xzPlane)
#       sketch.name = 'SecondComponent'
       lines = sketch.sketchCurves.sketchLines
       lines1 = lines.addByTwoPoints(adsk.core.Point3D.create(0,0,0)\
       ,adsk.core.Point3D.create(3,1,0))
       lines2 = lines.addByTwoPoints(lines1.endSketchPoint\
       ,adsk.core.Point3D.create(1,4,0))
       lines.addByTwoPoints(lines2.endSketchPoint\
       ,lines1.startSketchPoint)
       prof = sketch.profiles.item(0)
       triExt = newComp.features.extrudeFeatures\
       .addSimple(prof,adsk.core.ValueInput.createByReal(50)\
       ,adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
       extBody = triExt.bodies.item(0)
       extBody.name = 'TriangleBeam'
       newDoc.saveAs('myDoc',newFold,'','')
       exportMgr = design.exportManager
       fusionExportOptions = exportMgr.\
       createFusionArchiveExportOptions('D:/FusionData/CadTest')
       exportMgr.execute(fusionExportOptions)
       return text
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
#print('B',run('dummy_arg'))
print(3,'=',text)
instead of
(as in the current code)
the code works properly.
I thought that the .cast() just handles the "hints" and that the code would work properly without the .cast(), but perhaps my knowledge is still to poor.
Best Regards
Peter
4 REPLIES 4
pludikar
in reply to: Peter__B
your variable (design) is referencing a Class (convention is class names begin with a capital letter).  The class is basically empty until it's initialized - fusion does that when it starts up -
hence:
product = app.activeProduct => references the existing and initialized fusion object
You are right, the .cast() is just a mechanism to get Spyder to recognise the type and link to Spyder's autofill/hints.  It's not involved in the logic.
could also been
design = adsk.fusion.Design.cast(app.activeProduct)
I've also seen it used as:
design = adsk.fusion.Design.cast(None)
design = app.activeProduct
However, I've found *.cast() doesn't always give reliable and complete hints, but that may be just me.
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
Peter__B
in reply to: pludikar
Hi
The code works fine with
design = app.activeProduct     (design = adsk.core.Application.get().activeProduct)
and also with
but .cast() seems to do more than just handle the hints. In manuals I have found that .cast() is not involved in the execusion.
Can anybody explain why ?
/Peter
pludikar
@Peter__B
hi,
.cast is designed to be a wrapper.  If it has any other side effects, it'll be a bug.  Use dir() in the spyder command console and you'll see .cast will have no useful methods or properties.
e.g.
>>> dir(adsk.core.Application.cast)
['__annotations__', '__call__', '__class__', '__closure__', '__code__', '__defaults__', '__delattr__', '__dict__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__get__', '__getattribute__', '__globals__', '__gt__', '__hash__', '__init__', '__kwdefaults__', '__le__', '__lt__', '__module__', '__name__', '__ne__', '__new__', '__qualname__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__']
all the properties you see above, are, by convention meant to be internal to .cast (the __ before and after the name, signifies internal).  It's not that you can't access them, it's just that if you do, the result may be unknown.
.cast is like the plastic wrapper around a candy - it tells you what candy's inside, but it's not involved when you eat the candy.
In your example
>>dir(app.activeProduct) yields
['__class__', '__delattr__', '__delete__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__get__', '__getattribute__', '__gt__', '__hash__', '__init__', '__isabstractmethod__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__set__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'deleter', 'fdel', 'fget', 'fset', 'getter', 'setter']
and
>>> dir(adsk.fusion.Design.cast(app.activeProduct))
['__bool__', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__']
there are some differences between having the wrapper and not, but the differences are all internal - there are no added methods or properties.
I hope that helps
Peter
Peter__B
Thanks a lot, now I understand why it worked and did not work.
/Peter
