Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Edit text value in API
5 REPLIES 5
RobotBee
847 Views, 5 Replies
I have a simple model - basically a square with 9 holes in it and text at the bottom. I need to change the hole diameter and text based on a table of values. The hole diameter is easy to change base on a parametric value, but I can't seem to edit the text value with the API.
This returns the current text value, but errors when setting the text value to a new string (textinputitem.text = "booyah")
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        ui.messageBox("Running")
        design = app.activeProduct
        rootComp = design.rootComponent
        features = rootComp.features
        sketches = app.activeProduct.rootComponent.sketches
        bRepBodies = app.activeProduct.rootComponent.bRepBodies
        textsketch = sketches.itemByName("Sketch1")
        textsketchtexts = textsketch.sketchTexts
        textinputitem = textsketchtexts.item(0)
        actualwords = textinputitem.text
        ui.messageBox(str(actualwords))
Tags (3)
Labels (1)
5 REPLIES 5
kandennti
in reply to: RobotBee
RobotBee
in reply to: kandennti
I restarted computer and Fusion360 this is the error that I'm getting. Since you say that its working for you I'll make another model and see if I'm getting something odd going on.
JeromeBriot
kandennti
I tried it with the attached data, but there was no problem.
I don't know the cause of the error.
RobotBee
Ok so I think it is a bug.
Due to the way that I modeled the text it applied upside down so I used a -180deg angle to get it flipped over. Fusion360 is fine with the -180 but the API doesn't like the negative 180, when that is changed to +180 it works fine.
Thanks for the help get it sorted out!
