Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
DXFSplineToPolyline does not work on iMac OSX 10
3 REPLIES 3
dmkelso
234 Views, 3 Replies
I'm trying to workaround the spline bug in "Save As DXF", by running the add-in "DXFSplineToPolyline"  It doesn't work on my iMac/OSX10, so I recorded a Screencast stepping through the Python code, and uploaded it.
I'd appreciate any help you can give me to get it working.
3 REPLIES 3
bram_hendrickx
in reply to: dmkelso
I couldn't get the default version from the store working either, I did however have more luck using the latest version from GitHub: https://github.com/AutodeskFusion360/DXFSplineToPolyline_Python
Note, It still isn't performing to my liking, but at least it's doing something 🙂
dmkelso
in reply to: bram_hendrickx
Thanks for the lead, I'll give it a try and let you know how it works in my
hands.
bram_hendrickx
Good luck. Once you run the script, a new button should appear in you sketch menu dropdown!
