Announcements
DXF import utility - text import problem
damien.huvelle
damien.huvelle
Hi everyone,
@prainsberry
I'm having problems when tryin to bulk import some DXF.
when importing without checking the "import text" it works fine but I need to add this text.
any ideas about what I should do?
thanks a lot
prainsberry
Is there a specific error you are getting? Maybe an issue with the font you are selecting for the import? Do you have a sample?
Patrick Rainsberry
Developer Advocate, Fusion 360
damien.huvelle
I don't select any special font, just using the basic one (for exemple, monobloc). Here is a link to the dxf i want to import https://autode.sk/3hvxXb1
