Duplicate Geometry Created by Script
barryf1
barryf1
I created a script in Python to create a sketch on the largest face of a body.  The sketch is intersected with the body and the resulting sketch has duplicate geometry.  Can anybody tell me why?  To duplicate, create a sketch with a square and extrude to a cube.  Run the attached script, selecting the cube as the body.  The sketch will be created in a new component named DXF.  The script will be saved to disk as a DXF file, but it is the sketch that has duplicate geometry.
I think the fact that there is projected geometry is causing the problem.  I see no way to prevent the duplicate geometry from being exported to the DXF file.  Any help would be appreciated.
--thanks, Barry
kandennti
Hi @barryf1 -San.
Try using the addWithoutEdges method instead of the add method when creating a sketch.
barryf1
That worked.  Thank you!
