Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
DropDownCommandInput reporting wrong type
2 REPLIES 2
scott
76 Views, 2 Replies
This command input's .type() method reports 'NoneType' as the class type. To be more specific, the error is "NoneType object has no attribute 'classType(). Anyone else see this behavior?
Here's the entire error:
Failed:
Traceback (most recent call last):
File "/Users/xxxx/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts/Type Test/Type Test.py", line 12, in run
print(adsk.core.DropDownCommandInput.classType())
AttributeError: 'NoneType' object has no attribute 'classType'
2 REPLIES 2
kandennti
in reply to: scott
Hi @scott -San.
I tried it and it returns "adsk::core::DropDownCommandInput".
scott
in reply to: kandennti
Kandennti, thanks for checking. I'm getting the correct response when using .classType() on an instance of the class, but not when using it on the class itself. I used a workaround though, so problem solved.
