Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Drag selection with 'Edges' selection filter
3 REPLIES 3
k.kaluza
382 Views, 3 Replies
I'm trying to add 'Edges' or 'CircularEdges' selection filter to Selection Input and use it with drag selection.
What I want is to drag mouse over some component to select all of the entities that qualify for the filter (by drawing the selection rectangle), in this case all the edges or circular edges. Just like in a 'Chamfer' command.
All I can do is draw the selection rectangle and none of the seemingly qualifying entities are selected. But if I change the filter to eg. 'PlanarFaces' it seems to work.
I'm modifying script from this solution here: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/onslection-event/td-p/9399382
inputs = cmd.commandInputs
i1 = inputs.addSelectionInput(_SelIpt1ID, _SelIpt1ID, _SelIpt1ID)
i1.addSelectionFilter('Edges')
i1.setSelectionLimits(0)
How can I solve this problem?
Thank you
3 REPLIES 3
kandennti
in reply to: k.kaluza
Hi @k.kaluza .
If you want to make strict selection criteria, the selection filter is not enough.
Therefore, I think it is possible to set the desired conditions by using PreSelect Event and PreSelectMouseMove Event.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-0550963a-ff63-4183-b0a7-a1bf0c99f821
I made a sample to select only arc edges and sketches in PreSelect Event without using selection filter.
#Fusion360API Python script
#Author-kantoku
#Description-Select Event Sample
import adsk.core, adsk.fusion, traceback
_commandId = 'SelectionEvent'
_SelIpt1ID = 'Selectioninput1'
_handlers = []
_app = None
_ui = None
# https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-E3D24F04-8576-420E-B9AD-44746A6B12EE
class PreSelectHandler(adsk.core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        args = adsk.core.SelectionEventArgs.cast(args)
        # Temporarily disable the entity selection
        args.isSelectable = False
        # Get entity on mouse cursor
        sel :adsk.core.Selection = args.selection
        ent = sel.entity
        # Find out if you meet the requirements of your selection
        if not hasattr(ent, 'geometry'):
            return
        if ent.geometry.objectType == 'adsk::core::Circle3D':
            # Since the condition is met, selectable
            args.isSelectable = True
class CommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the select event.
# https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2ACFFC2F-458B-4740-93B8-CCC56638D8AA
class MySelectHandler(adsk.core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.SelectionEventArgs.cast(args)
        # Code to react to the event.
        _ui.messageBox('In MySelectHandler event handler.')
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd :adsk.core.Command = args.command
            onDestroy = CommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onPreSelect = PreSelectHandler()
            cmd.preSelect.add(onPreSelect)
            _handlers.append(onPreSelect)
            onSelect = MySelectHandler()
            cmd.select.add(onSelect)
            _handlers.append(onSelect)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDefs = _ui.commandDefinitions
        cmdDef = cmdDefs.itemById(_commandId)
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = cmdDefs.addButtonDefinition(_commandId, _commandId, _commandId)
        onCmdCreated = CommandCreatedHandler()
        cmdDef.commandCreated.add(onCmdCreated)
        _handlers.append(onCmdCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
I hope it will be useful.
k.kaluza
in reply to: kandennti
Hi @kandennti, of course it's useful. Thank you!
I'm still wondering why simply adding a filter to Selection Input doesn't work. Is this a bug?
After all, it works fine for selecting surfaces or sketches so why not for the edge, thus we need a workaround using another method?
Is it possible in the solution you proposed to filter out the sketches?
Thank you once again.
kandennti
Probably a filter bug.
I haven't tried it, but this old one may not have improved.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/select-sketchconstraints-using-api/m-p/806...
I've given up, so think about what to do with the PreSelect Event.
Fixed to exclude sketches.
    def __init__(self):
        super().__init__()
        ent = sel.entity
        if hasattr(ent, 'parentSketch'): return
        if not hasattr(ent, 'geometry'): return
        if ent.geometry.objectType != 'adsk::core::Circle3D': return
In PreSelectHandler, I think that you should narrow down until you meet the necessary conditions.
