Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Download an appearance programmatically
5 REPLIES 5
brad.bylls
175 Views, 5 Replies
Can you download an appearance to use as a sample to copy and make your own color with the API programmatically?
Brad Bylls
5 REPLIES 5
BrianEkins
in reply to: brad.bylls
Take a look at this blog post.  I think it might answer your question.
https://ekinssolutions.com/setting-colors-in-fusion-360/
Brian Ekins
brad.bylls
in reply to: BrianEkins
Brian,
Thanks for the reply.
I used your code sample originally when writing my code.
I didn't use 'Paint - Enamel Glossy (Yellow)'
Instead I used 'Powder Coat (Blue)', I didn't want glossy.
It worked fine for me.
However, when I sent my add-in to the app store for publication, their test said it was a bad name.
I did some testing and found that only downloaded appearances would work.
Not knowing what the end user may have downloaded, I want to know if it is possible to download programmatically.
This is my original code taken from your sample.
	plateTCPext.name = 'Plate TCP'
	plateTCPbody = plateTCPext.faces[0].body
	plateTCPbody.name = 'Plate TCP'
	fusionMaterials = _app.materialLibraries.itemByName('Fusion 360 Appearance Library')
	appear = fusionMaterials.appearances.itemByName('Powder Coat (Blue)')
	yellowColor = design.appearances.addByCopy(appear, 'YellowColor')
	colorProp = adsk.core.ColorProperty.cast(yellowColor.appearanceProperties.itemByName('Color'))
	colorProp.value = adsk.core.Color.create(204, 204, 0, 0)
	plateTCPbody.appearance = yellowColor
Brad Bylls
BrianEkins
I understand.  Unfortunately, the API doesn't have support for appearances that have not been downloaded.  Ideally, the list of appearances would contain both those that are downloaded and those that are not and have a property that would indicate if it has been downloaded or not and then either provide a way for you to download it or automatically download it if you attempt to use one that has not been downloaded.  In any case, that support is currently not available.
Brian Ekins
JeromeBriot
Create your own materials library. Then save it in a adsklib file that you place in your add-in folder. So the appearance will be available even if the user didn't download it previously.
I did this for the IDF import add-in and it works perfectly.
To load the appearance from the library:
import adsk.core, adsk.fusion, traceback
import os
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        product = app.activeProduct
        lib = app.materialLibraries.itemByName('myLib')
        if not lib:
            lib = app.materialLibraries.load(os.path.join(os.path.dirname(os.path.abspath(__file__)), 'myLib.adsklib'))
            appearance = lib.appearances.itemById('Prism-097')
            # appearance = lib.appearances.itemByName('Powder Coat (Blue)')
            product.appearances.addByCopy(appearance, appearance.name)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
That's the idea.
brad.bylls
in reply to: JeromeBriot
Thanks Jerome.
Thant worked out great.
Loaded F360 on a new computer for testing, so no appearances were downloaded.
Brad Bylls
