Doing a sweep up a spiral problem
brad.bylls
brad.bylls
Since the API does not have the ability to do a coil, I have created a spiral and a sketch to make the coil.
However, it does not work properly.
It starts out as a simple rectangle at the bottom, but as it goes up the path it twists.
I have tried ParallelOrientationType also, but that does not work either.
Below is the code to create the sweep.
    # Create a sweep input
    sweeps = newComp.features.sweepFeatures
    sweepInput = sweeps.createInput(profmyPathadsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    sweepInput.orientation = adsk.fusion.SweepOrientationTypes.PerpendicularOrientationType
Any help appreciated.
Thank you.
Brad Bylls
nnikbin
@brad.bylls , You can use a scaled version of your path as a guideRail. It works in UI, so I guess it works with API too.
In the following sample, the profile width is 10mm, the profile path radius is 25mm and the guiderail radius is 30mm. So:
guiderailRadius = profileWidth / 2 + pathRadius
Maybe it's better to use none for profile scaling so we do not have to worry about guideRail radius.
brad.bylls
That did it.
Thanks so much.
Brad Bylls
