Announcements
Dogbone will not run.
dkampWQTNE
dkampWQTNE
I have had Dogbone installed and working on my current machine. Today I needed to use it and went to launch it manually and got the error below. Have gone to Github for the newest release as Fusion has been updated quite a number of times so I first thought that it also needed an update. Not sure what the error means. Any help would be.most welcome.error.png
goyals
Looks like it is not able to find 'Resources' folder. This folder usually contain icons for the command. Please check if you have 'Resources' folder exists on your machine besides Dogbone.py.
I am not sure how you have installed this add-in. If you cloned it from GitHub then please get the 'Resources' folder as well from there.
Shyam Goyal
Sr. Software Dev. Manager
pludikar
Hi @dkampWQTNE
In case you are still either having issues, or are still using an older version of dogbones - a new version was released last week - it includes self extracting files for both Windows and Mac users, which puts the right files in the right places.
Go here, download and either execute, or read instructions (for Mac), everything else should be taken care of for you.
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
